Go Back   Home > Forums > Source & Line > Analog Line Level
Old 18th September 2009, 07:52 PM   #1291
jcx is offline jcx  United States
multitone IMD tests could use incremental frequency and/or amplitude changes of the input tones to help identify the order of the IMD products as long as the map is relatively smooth and continuous (not guaranteed)
would 192K soundcard test tone generation be acceptable? – I really think 1st order 100KHz filtered square wave is a little excessive for a audio amplifier test – know anyone using 1st order roll-off microphones?
Old 18th September 2009, 08:13 PM   #1292
Originally Posted by Wavebourn View Post
But you said before that you believe that a negative feedback around a thingy that itself creates PIM helps to decrease it, so may we assume that a class D amp with an additional feedback loop from speaker out will have less of PIM caused by filter cores?
the Class D output filter corner frequency severely limits the available bandwidth for global feedback around the filter (Bode Integrals anyone?) - but using BJ Lurie's ideas a higher order loop gain shape could allow some audio frequency distortion reduction - including the PIM components from the inductor that fall in the region of negative feedback - assuming (2nd order?) output filter corner frequency more than an order of magnitude higher than the region of functional negative feedback (audio range negative feeback limited to a fraction Fc/20KHz ratio and impacted by filter order)
http://books.google.com/books?id=-go...age&q=&f=false
(the luriecontrol website seems to be undergoing modification)
Old 18th September 2009, 08:15 PM   #1293
gerhard is offline gerhard  Germany
gerhard's Avatar
That's exactly what I did in post 1032. I moved one tone a few Hz and the
IMD product moved n times as much, according to the order of its dependence
on this tone.
A sound card would be ok. Maybe the square wave should be clipped and then
low pass filtered again to make its risetime independent of the sound card.
Gerhard
Old 18th September 2009, 08:35 PM   #1294
Yes, that is true, but I pointed out parenthetically that closing the NFB loop around the output filter can be difficult because of the lagging phase shift introduced by that filter.
Unless I am missing something, getting the output filter inside the NFB loop while retaining any meaningful amount of NFB at 20 kHz is very difficult.
Another very good reason to try to get the output filter inside the NFB loop is damping factor. A 20 uH inductor in the filter will reduce the damping factor at 20 kHz to about 3. I believe that having a decent damping factor out to 20 kHz is desirable (although at that frequency a DF of 20 is probably adequate).
Bob
Old 18th September 2009, 08:42 PM   #1295
syn08 is offline syn08  Canada
Yes. I've seen quite some time ago a (pretty indigest) Signetics App Note related to negative feedback in class D amps, it should still be available on the Signetics web site.
Old 18th September 2009, 08:55 PM   #1296
gerhard's Avatar
Originally Posted by Bob Cordell View Post
Any nonlinearity in the inductor usually manifests itself as current-dependent inductance. Thus, we have a pole moving back and forth with the signal current, causing in-band phase shift changes. Voila, PIM.
I think this is not much different from a VAS stage that modulates its
Ccb depending on the momentary Collector voltage.
Whether it can generate anything but normal harmonics and mixing products
depends upon whether we are willing to accept that amplifier/excitation system as cycle-stationary.
For a spectrum analyzer it is for sure, so I don't think that we can find anything.
Maybe if we could do FFTs over partial cycles we could see some momentary change,
but we could not express this in Hz because the Fourier transform
is simply not defined for anything shorter than an eternity. Perhaps we need
a Laplace analyzer. ;-)
I don't like math.
Gerhard
Old 18th September 2009, 08:58 PM   #1297
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
...now assume we used an air core inductor, so no PIM generated by it, then applied a negative feedback around this filter.
What should happen, if the entire amp around which we applied the FB is not perfectly linear?
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 18th September 2009, 10:03 PM   #1298
First of all it’s good to see that this thread has moved in to this millennium.
Discussing the future in high-end power amps (aka Class D)
Bob
Yes of course PIM is a problem if you include the output filter in the closed loop, it is obvious, and as you say it, we would like to include the output filter in the closed loop to get a better damping factor.
As I see it that is the same problem and the same wishes we have with all amps, no matter what classes we are talking about.
Show me one amp no matter what class with no (nada) PIM and a good damping factor.
OTOH I don’t think it’s fair to generalize all so called class D amps into one group and say that they have this and that problem. Maybe there are just as many different ways to design a (so called) Class D amp as there are ways to design a (so called) Class A, Class AB or Class B amp?
What do you think guys?
Cheers
Stinius
Scott, I have redesigned the amp so just throw away the schematics I sent you. BTW have a nice trip.
Old 18th September 2009, 10:33 PM   #1299
Wavebourn's Avatar
I started building one for you, but you've stopped answering e-mails as soon as I said that you have to share at least some expenses.
Old 18th September 2009, 11:09 PM   #1300
This happens a lot in my world, also, Wavebourn.
For everyone else, I don't know what to say about the inductance variation. It can be very important, I'm sure.
However, I am in a situation where I can't address this topic here.
I will try to continue on a separate topic, once one comes up that I can contribute to.
It is interesting that I brought up this topic with one of my associates, and he said 'What inductor is actually linear? Apparently he has looked deeper than most, but I brushed it off, saying that we have to use 'something' and air coil looks pretty good to me, compared to many other types.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
john curl
Page generated in 0.22317 seconds (58.33% PHP - 41.67% MySQL) with 11 queries
