| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#12941 | |
Or when you attempt to pass off your subjective experience as something more than simply your subjective experience. se
The Audio Guild |
#12942 | |
Historically ringing on clipping went unnoticed for several years! there still are amplifiers made that do that! So yes with hindsight we should not make that mistake, we have so many new ones left! ES Steve, The brass seems like a good idea, but the thieves would mistake it for gold and then get upset when they found out otherwise and take it out on me!
#12943 | |
se
The Audio Guild |
#12944 | |
![]() Edit: Aw man, I thought they'd eased up on the silly-*** nanny filter. ![]() se
The Audio Guild |
#12945 | |
This is a pure speculation on your part, probably cased on your beliefs. |
#12946 | |
Without the data, the 'audiophile' hardware, nor the expertise to back it up. Factual observations + circumstantial evidence = rational assumption, till proven otherwise. (forgive me father, i myself have commited arrogance display again)
Not so much,.......if it says "ZM" in the corner. |
#12947 |
#12948 | |
[QUOTE=Joshua_G;2611511]
Anyway, yes, the facts. I have understood from various posts by you that you don't agree that non-auditory clues may influence your assessment, and that consequently you don't take measures to make a listening test controlled. If that is correct, I am not interested in the details how you do your test as the results will be personal to you and not very interesting to me. If this is not correct, if in fact you have chaged your mind and agree that tests should be controlled to prevent non-audditory clues to influence your assessment, I am quite interested in how you set up such a controlled session. jan didden
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun |
#12949 | |
se
The Audio Guild |
#12950 | |
I think I will stick with my tin ears, that way I won't have to get into silly debates over what one can hear versus what can be measured. I'll stick to the debates on if what you are measuring has any influence on what can actually be heard. ES |
