| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
| Thread Tools | Search this Thread |
#1201 | ||
I never tried to load infinitely high output on infinitely low input; however I used similar things deliberately creating guitar effects, but never tried for a high-end audio. How good are OL parameters of such a thingy? You should know better than me... Quote:
Non-harmonic content can't prove presence of PIM. It may prove presence some say thermally-induced oscillations that cause something not related to signal spectra, or harmonic content may look like non-harmonic when intermodulaions occur between periodic signals and their envelopes (discussed with Jan Didden), but no way non-harmonic content can signify presence of phase modulation. "Amicus est Socrates, magister meus, sed magis est arnica veritas." (C) Last edited by Wavebourn; 17th September 2009 at 02:22 AM. |
#1202 | |||
Agreed wholeheartedly. |
#1203 | ||
Hi John,
I really do think you need to read other people's responses more carefully. Many people have now pointed out the normal and proper way to investigate any phenomenon. You discover something that you make note of. You recreate the observation, and once you can do that reliably, you make sure you don't have an error in the experiment. Once you are sure no errors have been made, you invite peer review and perhaps write a paper on your work. This would include the exact test setup, stimuli (test signals) and any other pertinent information so that your observations can be replicated by others. In this case, you want to see other experimenters come up with the same data. At this point, conclusions are not important. It's the validity of your experiment that is the critical question. Quote:
"If it looks like a duck, quacks like a duck, maybe it is a duck, or just possibly it's a decoy, a smudge on your glasses or whatever else was in the bottle along with the alcohol". Note that I'm not suggesting that you drink, just looking at a better comparison. Now, you say it was a duck. Did you manage to get a picture so we can all have a look? As said before by many other members, we can accept things exist that can not be measured at this time. No argument there, so you can drop that issue. More than one member has expressed interest in running your experiments as close to the original set as possible. The hope is that others can recreate what you were seeing. This is not an attack of any kind. This is called "peer review", and this is part of any technical announcement. You can not expect for a moment that anyone will simply drop what they know in order to accept what you are telling them without any experimental data or other proof. You wouldn't, but you are expecting everyone else to do exactly that. Can you see why you are being questioned about these things John? Now, for the benefit of all members, would you please draw out your experiment exactly, along with signal levels and any other information that might be required? This would go a long way to unifying everyone here and get them onto your page. Then you can talk about these things in a meaningful way. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#1204 |
Regarding audible vs. inaudible - some people are easily able to tune the guitar, some are not and do not hear it is out of tune - they would need a frequency meter to tune it and tell if it is tuned. Why to expect that hearing abilities are same for all people?
#1205 |
Also, hearing and perceiving are different things.
#1206 | |
Mr. Curl, I posted in this thread some pictures. One show the same spectra, as 741, and it is simple two diodes limiter. It is FM ? |
#1207 |
The point I was making about the reference to the piano tuning was that a harmonically correct distortion that should sound like normal instrument harmonics may actually not correspond to the real sound and to a sensitive listener may sound "wrong". The point of this observation is that we can't accept any generalization on the audibility of distortions or lack thereof. The assumptions need to be tested.
As for linear distortions I belive it is accepted that very small frequency response errors, on the order of .1 dB over a large range, can be heard. However small peaks and dips can be very hard to discern. I know from experience small changes in RIAA eq can have a major effect on the perceived sound, but sonically don't match what the actual change was.
Demian Martin Product Design Services |
#1208 | |
http://www.linearaudio.nl/Miscellane...0recorders.pdf I had a cursory look and it appears that the paper addresses all those 'unexplained' spectral lines in the famous Fig 3. jd
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#1209 | |
jd
#1210 | |
You are missing the point of these discussions massively. It is not about whether science has answers or not. It is not about whether PIM or TIM exists or can be audible. That is not contested as such. The discussion is about answering questions about a statement that is made, about providing arguments that support your position so that others can judge for themselves instead being limited to 'believe' or 'not to believe'. Providing full details of your measurements, so that others can repeat them and either confirm or falsify them. In other words, intellectual honesty. jd
| Currently Active Users Viewing This Thread: 4 (2 members and 2 guests) | |
| kannan_s, riccoryder |
| Page generated in 0.31832 seconds (66.34% PHP - 33.66% MySQL) with 11 queries |
