| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
| Thread Tools | Search this Thread |
#11281 | ||
You are confusing the direct measurement of electron movement with the coupling of a magnetic field caused by the movement. A hot wire does not produce external magnetic field more than 5 to 10 nanometers from the surface. Quote:
Your definition of "good conductor" and mine are worlds apart. You live in the world of ampere per square mm, I live in the world of kiloampere per square mm and no electron-lattice interaction. Read my previous post on "excess noise". Perhaps that will help you understand what I'm speaking of.. Cheers, John |
#11282 |
Sorry, when you said shot noise I assumed you were talking about shot noise. Excess noise may also be present, of course, and scattering may well be a component of this. And thermal noise from all dissipation mechanisms.
As often on this site (and this thread), I wonder what all the fuss is about. We seem to have finally established that thermal noise is a significant (dominant, only?) contributor to transformer noise, and that this can be calculated by measuring the resistance at a particular frequency and estimating the temperature. This will be ambient for an input transformer - otherwise we would have to do separate calculations for windings, core and any other source of loss as they may have different temperatures. If thinner laminations give lower Q and higher noise, then that is exactly what we would expect if eddies are a factor. |
#11283 |
So you have a one-way coupling? Windings couple to core, but core does not couple to windings? You can have dissipation without fluctuation? What sort of physics is that?
#11284 |
Interesting point, but SMPTE IM is a subset of real IM, and I would think not relevant in this case.
#11285 | |
If a resistor, by itself, generates noise, presumably we can harvest that as energy. Where's the energy coming from? Would we cool down the universe when we would harvest it? jan didden
/Another new issue: Linear Audio Volume 3! |
#11286 | ||||||
It is what Schwartz called it in "Information Transmission, Modulation, and Noise..McGraw Hill, 1970. Page 512 on.. Quote:
![]() The fuss is because every person is an individual entity, living, breathing, and in need of being convinced that their opinion is not the correct one, and tht everybody MUST conform to (my) opinion... That was an easy question... ![]() ![]() Quote:
What was asserted was that hf noise is somehow dependent on lamination thickness, and I attribute that to eddy current loss. Quote:
Do not confuse the magnetic coupling between the coil and core with thermal motion which does not produce a macroscopic magentic field. The random thermal movement of electrons within the core do not create a magnetic field which the coils can see. As I stated, 5 to 10 nanometers from the surface, local magnetic fields are gone, integrated out.. That is below the surface oxides. Cheers, John |
#11287 |
WELL SAID, DF96. However, thicker lams give more noise, skinny lams less noise, but are hard to make and work with.
#11288 |
If you could harvest the energy, then yes you would cool the resistor. This energy comes from whatever heated the resistor in the first place. Doing this would not cool the universe because the energy you extract will all end up as heat again eventually. Remember what thermodynamics says: you can't win, you can't even break even for long.
Almost any method you think of for harvesting the energy would end up being either inefficient, or putting just as much energy back. One possibility is to take another resistor of the same value, which just happens to be near absolute zero in temperature. (We will gloss over how much energy it took to cool it). Connect the two resistors together with wires which are good electrical conductors, but poor heat conductors (if you can find them). Then the hot resistor will cool, and the cold resistor will warm up. They will reach equilibrium at their original mean temperature. Don't hold your breath, as this may be a slow process unless they are very tiny in size. kT is not a lot of energy, unless you are trying to make a radio receiver or a phono pickup. |
#11289 |
Sorry, yes "thicker lams".
Temperature does matter, unless we simply assume that all relevant items are at the same temperature. May be OK for a phono preamp, as they will be near ambient temp. However, we are used to calculating noise in voltage or power terms and for that you do need temperature. I am not convinced that there is one-way coupling. You seem to have created a magnetic black hole! As I said, dissipation without fluctuation. A loss mechanism which generates no noise. I don't believe that. |
#11290 | |
And 4.5K requires 1 kilowatt of refridgeration power for every watt dissipated. 1.88 K requires double that.. If anybody can find a good electrical but bad thermal conductor, I know a few facilities that will buy TONS of it. Cheers, John |
| Currently Active Users Viewing This Thread: 4 (2 members and 2 guests) | |
| jcx, bmcevers |
| Page generated in 0.23768 seconds (57.23% PHP - 42.77% MySQL) with 11 queries |
