Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th March 2011, 03:40 PM   #11181
scott wurcer's Avatar
Originally Posted by Soundminded View Post
An awful article. A prime example of why I not only don't subscribe to this magazine, I rarely read it even for free and never take anything it says seriously.
ftp://194.45.31.243//Parasound/Revie...rch%202011.pdf
I've been to the home of one of the folks mentioned in the article, the listening protocall was to say the least not rigorous. $26K on the word of two partying dentists? BTW did they mention if they loaded the cart the same for all cuts? If not....
2012, our time is running out.
Old 13th March 2011, 03:44 PM   #11182
Steve Eddy's Avatar
Originally Posted by john curl View Post
Direct measurement comparison between the mumetal and amorphous transformers: LL1931, and LL1933, show a VERY large difference in distortion at 10Hz.
That's probably because Per isn't using cut cores in the LL1931.
That means no air gaps, which means higher efficiency (more like a toroid which also doesn't have an air gap). That means that all else being equal, it will saturate sooner than a laminated core or a cut C core.
se
Q
Keeping it simple since 1998
Old 13th March 2011, 03:44 PM   #11183
Moving coil input, simple ratio 5:1 optimum, 10:1 usable. Load, paralleled differential jfets giving an equivalent input noise from the fets alone of about 0.5nV/rt Hz. Need to extend to 0.2nV/rt Hz or so, with transformer, so DC resistance is important.
Old 13th March 2011, 03:46 PM   #11184
The protocol was a joke. The first thing the guy did wrong was to record them on a cd. Since those who swear vinyl is the ultimate recording and MC cartridges the only way to listen to them detest cds with a passion, as soon as any signal passes through that filter they'd consider it all but worthless. And that's just for starters. The article IMO was as worthless as the tests, merely a space filler to sell magazines. Now he had played recordings of dentist's drills, a sound they'd be familiar with.....
Old 13th March 2011, 03:47 PM   #11185
SY's Avatar
Did I overlook the part about level-matching?
“There are no greater liars in the world than quacks, except for their patients.” - Benjamin Franklin
Old 13th March 2011, 03:50 PM   #11186
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by pieter t View Post
being a socialist I actually give them away for a small additional fee
Mr T,
in that case, may i suggest a last name change.
Looks like Sponge Bob has killed another thread.
Old 13th March 2011, 03:50 PM   #11187
pooge is offline pooge  United States
Yes, Scott, presuming the transformer is IDEAL! However, there are differences between transformers, and I seek to find these differences. Then I can chose between them.
It is POINTLESS for me to put in a less than optimum transformer. I am willing to go as high as 200 Euros / transformer, in limited quantity, 100 or so. Pieter, can you work in this range?
Stevens & Billington Limited Audio Transformers
Old 13th March 2011, 03:53 PM   #11188
Steve Eddy's Avatar
Originally Posted by pooge View Post
I thought they stopped selling transformers to DIYers and OEM's?
se
Q
Old 13th March 2011, 03:54 PM   #11189
S & B transformers have too much self noise. 0.8nV/rt Hz. They may sound good, but they will not help in my application.
Old 13th March 2011, 04:00 PM   #11190
SY's Avatar
The spec is 0.8nV of noise, not 0.8nV/rt Hz. It doesn't appear to be a noise density spec, nor were they kind enough to specify bandwidth. I didn't see a DCR spec, but from the winding description, it's presumably close to the same as the other good MC step ups.
I think that for Pieter to design the transformer properly, you'll have to spec the input capacitance of the FETs in your circuit.
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
jcx, bmcevers
Page generated in 0.24189 seconds (58.00% PHP - 42.00% MySQL) with 11 queries
