| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#11041 | |||
and somehow adopt my point as your objection??? ... Quote:
on average, long term, "net" /= measuring frequency dependant noise Quote:
Cheers, John[/QUOTE] Last edited by jcx; 11th March 2011 at 08:21 PM. |
#11042 | |
If we leave joule heating out of the equation for the moment, the only source of noise is thermal energy from the ambient room temperature, yes? se
The Audio Guild |
#11043 |
Yup, a resistor has an open circuit voltage noise and a closed circuit current noise. I thought the skin effect would not effect the voltage noise, but I will have to think about that some more.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#11044 |
SE, you almost have it. Of course, the inductance drops a little, BUT not enough to track the radical departure in Q that the head (or transformer) will measure. I'm glad to see you thinking it through, however.
#11045 | |
#11046 | |
se
The Audio Guild |
#11047 |
Gents,
A most enjoyable and thought provoking discussion. Honestly, one of the best I've had here.. One learns more through conveyance of differences in opinions. I'll jump back in monday. Cheers, John |
#11048 | |
se
The Audio Guild |
#11049 | |
What about using a litz air core coil, pushed at 20Khz 1 ampere, with an analyzer on the terminals....then insert a piece of brass, aluminum, or copper to see if it's eddies cause the noise to change? Cheers, John ps...you too steve. |
#11050 |
J.G. McKnight, personally, just conformed my understanding of eddy current losses and their contribution to reproduce noise increase at high frequencies. End of debate.
