| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#10991 | |
se
The Audio Guild |
#10992 |
As I mentioned before, I tried this with millivolt signals driving the primary of a large OPT (vintage 1980 or so, 1250 ohm: 16 ohm, CT) through series resistors to try to measure the phenomenon that Menno predicted. Couldn't find any issues despite the transformer having a very conventional EI oriented ss core and being made for large signals (600V at hundreds of milliamps). Maybe there was something special about this transformer that I wasn't aware of, but I doubt it.
And of course, we don't see any significant distortion from MC step-ups or good mike transformers, though to be fair, the MC step-ups driven by very low source Z. So no sleep lost here, either, at least not because of this hypothesized aspect of transformers...
If there's a sucker born every minute, where do the rest of them come from? |
#10993 |
Yes, but in this case the real part of the frequency dependent impedance due to skin effect will contribute sqrt(4KTR). So we have experiment no 2.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#10994 | |
You can also keep a ball up with a backwards vaccum cleaner. The energy to make a tornado is staggering and it only gets you out of Kansas.I do the Golf Channel now and some revisiting of Poe.
#10995 |
Thanks Joachim, your input has been very helpful.
#10996 |
Thanks. That pretty much answered my next question, too.
Now I can sleep better.
Take the Speaker Voltage Test! |
#10997 | ||
http://focus.ti.com/lit/ml/slup197/slup197.pdf Regards George
"Second Law is a bitch." - SY “Not to worry, audiophiles don't normally get past the Gate anyway.” - rdf |
#10998 | |
![]() ![]() se
The Audio Guild |
#10999 |
Steve,
..............here is something more your speed. Transformer Animation - Alternating Currents | Tutorvista.com Jam
#11000 | |
I see you emphasized "Losses" in the title, but you overlooked "Windings." He says absolutely nothing about the core materials, which is what is being discussed here. He's just talking about skin effect and proximity effect in the windings, specifically as it relates to transformers for switchmode power supplies which use high frequency pulses and depending on how much power is needed, rather large gauge wires which make skin and proximity effects much worse. What we're talking about is audio transformers, which are using wires on the order of 42 gauge. With such small diameter wire, skin and proximity effect are effectively non existent at audio frequencies. And again, it's not the windings that are at issue, but rather the alleged added noise due to eddy current losses in the core. se
The Audio Guild |
