| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
| Thread Tools | Search this Thread |
#1061 |
Thanks for your effort here. This is very close to my earlier assertion that the frequencies were 2f2-9f1 = 1380 and 11f1-2f2 = 4980. Throughout this exercise, we all must be mindful that this is not a high fidelity measurement by any stretch of the imagination. The Figure 3 example is pounding the cr@p out of a known cr@ppy op amp. It would be far more interesting to see the same results for a modest-fidelity modern op amp under the same conditions. Maybe something like an OPA-604. It is not the least bit surprizing that this kind of amplitude spectra can be created by fm modulation, but that only underscores the fact that with amplitude spectra alone it is virtually impossible to discriminate between TIM and PIM. It in no way supports the assertion that these sidebands show that there is PIM. Cheers, Bob |
#1062 | |
![]() I've found this picture for you googling for FM sidebands: http://www.radio-electronics.com/inf...m-tutorial.php Edit: you may see that for FSK you've mentioned bandwidth will be needed is double deviation plus double baud rate. I.e. if you limit bandwidth of transmitter and receiver by double deviation you won't be able to transmit FSK. Also, you may search for phase modulation methods to obtain SSB. They were (and are) still used in radio. The plus is, they don't require expensive mechanical filters, and such SSB modulators can be micro-miniaturized. Last edited by Wavebourn; 7th September 2009 at 09:37 PM. |
#1063 |
Wavebourn, .5 looks pretty good to me, for this. What do you think?
#1064 | |
If you mean how nasty sounds mixed phase and amplitude intermodulation, I think you may get an impression listening to SSB transmission on AM receiver. By the way, here is a SSB modulator designed by Russian ham radio operator A. Polyakov (RA3AAE), you see how it is easy to get a nasty SSB sound just summing clean and phase modulated signals (that happens in opamp-based amps easily):
#1065 | |
Thanks for providing the article. Though I really don't want to get in to the whole TIM/DIM/PIM debate. It's just that y'all were arguing over what was shown in fig. 3. You'd previously labeled some of the peaks in it, and John questioned whether or not they were accurate. So I thought I'd use some of my CAD/graphics skills to get a better fix on what frequencies the unlabeled harmonic components were. se |
#1066 | |||
Hi Anatoliy,
Thank you, I am very familiar with modulation types. Now, just above the pictures you posted for us, there is some text that I feel is relevant and important to consider. Quote:
First, an infinite series of frequencies (Fourier equivalent of a square wave) all modulated together by a since wave. Man, that's some kind of spectral mess you'll have there! Second, a sine wave modulated by that same series from the square wave. Even limited by the 100 KHz filter, you will have your hands full figuring out that mess. Look at the input signal. From the posted test circuit, you can see it's a linear adder. The resultant signal will be an amplitude modulated signal. If you pass this through a non-linear amplifier (A 741 qualifies for higher frequencies), you will produce a fair amount of harmonics added into the output signal. Okay, no problem. So, how are we producing a large amount of FM modulation here? Wouldn't the phasing effects be clearly audible if this distortion was as high as John says it is? What I would expect to see is a small amount of FM produced. These should be at a low amplitude. Maybe even buried in noise compared to the AM products. The audible distortion produced by a 741 op amp does not have a phase component that is large. I've heard 741s in audio circuits often enough, and they produce more of a nasty harmonic type sound. Not that I was ever concerned with looking at them closely. Perhaps I will soon enough. Quote:
Hi John, Quote:
I don't have a problem with some small amount of FM modulation being produced by an op amp or circuit in distress, but I balk at the possibility of seeing such large amounts, comparable to the amount of AM distortion products. I guess that's my main beef with the interpretation you're reaching for. Not only that, but we've seen you're a little hazy on the details as well. No surprise, because the experiment happened so long ago and I believe you have lost all your original data and notes in the fire you had.
"Just because you can, doesn't mean you should" © my Wife |
#1067 |
Lazy, ME!
Here I am, 67 1/2 years old, half blind, 2 fingers asleep that make it difficult to type, and here I am, trying to help others understand a little of what I have found over the last 40 years. Think what I could do, if I found something important to do.
#1068 |
OH, you said 'hazy'. NEVER MIND !
#1069 |
Hi John, Yes, hazy. Things that I did 30 years ago are pretty hazy, if not entirely gone from my memory. Many of us have various problems. I come down with hands that go asleep with no warning, plus a host of other issues. Take your time and post as you can. There are days that a few posts represents all I can do for that day, and it has nothing to do with being lazy. Anyway, John. There was a test setup posted a short while ago. Does this look like the setup you fellas used. If not, could you, or would you let me know so that I may try some of this out? What order of magnitude would you expect the FM (or phase) products be? Thanks John, Chris
#1070 |
| Currently Active Users Viewing This Thread: 5 (2 members and 3 guests) | |
| jcx, bmcevers |
| Page generated in 0.23478 seconds (59.85% PHP - 40.15% MySQL) with 11 queries |
