| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#10611 | |
I've also learned that hearing can become quickly adaptable. That is why making critical adjustments for each recording is an iterative process. It isn't finished until I come back after some hours or days and it still sounds the way I remember it the last time I thought I had it right. |
#10612 | ||
You should have been making thousands of dollars off that. Quote:
se
The Audio Guild |
#10613 | |
Banned
w |
#10614 |
I still find it interesting that you think your style of listening might have commercial potential.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#10615 |
We made them good, so we have had few returns.
#10616 |
Personally, Soundminded, while I do not criticize your choices of what to listen to, and how loud, I would rather not bother, and I passed the audiometry test too!
#10617 |
Mr Weedy-B,
'cough', you do realise that still leaves 2 options. (of which i gathered neither is a safe bet)
Not so much,.......if it says "ZM" in the corner. |
#10618 | ||
Tom and David (the company's VP) are good people. And if you ever call, it will be either Tom or David who will answer the phone. se
The Audio Guild Last edited by Steve Eddy; 5th March 2011 at 08:04 PM. |
#10619 |
Huh?
If you had few returns, how could those few returns have cost you "many thousands of dollars" as you stated previously? If I'm not mistaken, you never made more than a dozen or two, yes? se
The Audio Guild |
#10620 |
Depends. When your ground gets down and dirty all sorts of nasties happen. You can define them as you want, but here is the picture of the same amp different ground schemes, (One of a series so it is not variation of parameters)
