| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
| Thread Tools | Search this Thread |
#10301 |
I've had several millionaire friends with Bose 901's and old Macintosh amps and they were in heaven. As W. C. Fields said never smarten up a chump.
2012, our time is running out. |
#10302 | |
One difference in our experience, I never exposed my ears to 130 db unprotected even unwillingly and I do not like the kind of sound produced by groups like the Grateful Dead, never did, never will. In that regard, it seems with time, age, and experience, your views have come closer to mine than the other way around. As you have not produced the perfect sound system yet, you should be at least tolerant if not open to views other than your own. You may not agree with them, you may not even understand them, but until proven wrong, they have as much chance of being right as yours do. Last edited by Soundminded; 1st March 2011 at 10:39 AM. |
#10303 | |
Even after re-engineering, it cannot reproduce the acoustics of a large hall or any other hall for that matter. What it can do when carefully adjusted for each recording is to accurately reproduce the sound of musical instruments as they would be heard if they were in the same room with you. This restricts its usefulness to soloists and small groups. Its main shortcomings IMO are 1) it cannot reproduce the highest octave of sound, 2) it has a substantial peak in the upper bass/lower midrange, and 3) its deep bass falls off too fast starting at around 200 hz. It falls at 6db per octave and reaches the 1khz level at around 90 hz below which it keeps falling. This requires additional bass boost increasing its power requirements to reproduce the lowest octaves substantially. Therefore it eats up power like a sponge. It may be the least efficient speaker at low frequenies I've encountered. Without multiple pairs and lots of amplifier power its deep bass output is therefore somewhat limited even in a small room. However, within its power handling capabilities, it will compete against much larger speakers like Teledyne AR9. Starting with Series III, the design changed from acoustic suspension to ported. I haven't had any experience with any of the newer models but I expect that efficiency increased at the sacrifice of the lowest octave. Listening to Series VI in a mall in Newport Beach Ca about 3 years ago, it seemed to me to have the same dull inadequate high end the originals have. |
#10304 |
"No Highs, no Lows...that's Bose" - standard saying in the pro sound reinforcement world.
#10305 | ||||
Dave. |
#10306 |
Well Dave, at least you can hear the difference. Yes, what I meant to convey was that I purchased an Ampex pro tape record recorder back in 1967, in order to record my favorite vinyl records and put them on tape, in order to save the extra wear on the vinyl, itself.
The REAL DIGITAL challenge, is: WHERE DID THE LIFE OF THE PERFORMANCE GO? Some say: 'It is just our imagination' others say: 'You are just prejudiced about digital', yet others say, that many of us miss the distortions often audible in a poorly engineered analog recording and playback. I, personally, would like digital to be as good or even BETTER than analog. Now, I don't have a lot of investment in digital, myself, but many of my customers do. I have been invited to listen to a 1/2 million dollar system, on occasion, and I want to leave the room, after 1/2 hour, if the presentation is digital. If vacuum tube amps are used, maybe 1 hour would be possible. Still, vinyl rules, and the was shown at the latest CES in several of the best demonstrations. Why? Because it conveys the 'EMOTION' of the performance, not just the information about the performance. Go figure. If we solve this, then we will have solved the digital-analog dilemma. Last edited by john curl; 1st March 2011 at 02:41 PM. |
#10307 |
Might be that pure technical means are unable to re-create original sound field, thus emotion transfer is impossible. That's my view.
#10308 | |
se Last edited by Steve Eddy; 1st March 2011 at 03:11 PM. |
#10309 | |
Between the time the vinyl and cd were issued, the master tape may have deteriorated. The dynamic compression of recordings edited for vinyl records can have desirable effects by making the last part of each musical phrase and the recorded reverberation louder. The skill in mastering the vinyl version may have been greater than the skill used in mastering the cd version. Choices of equalization in the vinyl era were made using speakers that were equalized for flat response, their calibration often checked weekly by the larger recording companies creating greater uniformity of the spectral balance from recording to recording, record company to record company although there were variations. Many recording companies used the same speakers for monitoring, Altec VOTA A7-500. In the CD era not only do companies use different speakers, the idea of equalizing speakers is out of favor and spectral balance even on the same label is all over the map. In one instance, even recordings of the same group played by the same musicians in the same studio but recorded by different engineers and issued on two sequential catalog numbers from the same company are substantially different. A comparison between the cd version and vinyl version of Carol Rosenberger playing Water Music on a Grand Bosendorfer piano on the Delos label sounded identical to me. The vinyl was played on an Empire 698 with a Shure V15 type V MR and the cd was played on a Toshiba DVD player circa 2007 with a 192khz 24bit processor. That CD player sounded identical on factory made duplicate cds with a JVC 1 bit 8x oversampling player circa 1991. Even their output level was indistinguishable. Conclusion, both players perform their function flawlessly. They are good enough for any audio recording. If there's a problem, it's elsewhere. |
#10310 |
Well, lots of opinions and very little 'proof'. My 'proof' is in my experience making recordings, hearing digital 'equivalents', using direct disc vinyl as a good reference, for fidelity, and the experience of my colleagues ACTUALLY WORKING in the audio industry, rather than 'arm chair' critics who dabble in audio design, and in truth, confuse me with the contradictory conclusions that they come up with.
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| bmcevers |
| Page generated in 0.29288 seconds (67.89% PHP - 32.11% MySQL) with 11 queries |
