Go Back   Home > Forums > Source & Line > Analog Line Level
Old 10th May 2009, 12:08 AM   #1
Default HELP channel select on guitar amp
Hi everybody. I've run into a design challenge that I need to sort out on my tube guitar amp.
Current set up:
The 3 channels are all separate modules that have their own independent 1/4" output.
What I need:
I need to figure out a way to select between the 3 channels using a footswitch plus allow for another channel which is a blend of all three channels, then route all the channels to go out to a single 1/4" output.
I was thinking of using an opamp or summing amplifier circuit much like a mixer so that I can mix the three channels, but I need to be able to have either 1 of the 3 activated at any one time or all three at the same time...
I will be doing most of the design work, so I don’t have any details to give you, however I need a sort of example to go off of, or some ideas that could help.
Last thing, I need it to be almost completely analog, with no digital IC's I want to be able to keep the signal integrity, no degradation at all.
Any help would be greatly appreciated.
Thanks,
Brendan.
Old 13th May 2009, 11:23 PM   #2
mjf is offline mjf  Austria
hello.
if you can find a footswitch for this...............
perhaps it can help.
greetings............
Simple technique for guitar amp channel switching? leadbelly Tubes / Valves 2 2nd September 2008 02:32 PM
Guitar amp channel question Trepan Instruments and Amps 3 22nd May 2007 04:46 PM
Using a spdt switch to select between triode mode and pentode mode on a guitar amp. G Tubes / Valves 19 15th March 2006 10:15 AM
How to Select an Enclosure BAM Subwoofers 8 9th April 2005 04:44 PM
Page generated in 0.06823 seconds (65.53% PHP - 34.47% MySQL) with 11 queries
