Go Back   Home > Forums > Source & Line > Analog Line Level
Old 2nd April 2009, 11:32 PM   #11
anatech is offline anatech  Canada
anatech's Avatar
Hi Brad,
DDS from the PCM1704 could be paired with analog-to-digital conversion from a PCM1804 to provide a flexible analysis tool, instead of just generating pure tones... though it's basically a novelty soundcard now
Hardly!
Now you are beginning to chase an Audio Precision type system. The generator and A/D sections are two completely different projects that could be included in the same case. Note I didn't mention "card", as in "installed in a computer".
To get the low noise and THD you want, plus input and output signal conditioning, you would need a larger box free from switching power supply noise. It would help to ventilate some of the components that would run warm. That's a side effect of chasing the low noise figures. It's no mistake that AP used an external box for all the analog signal processing. It's all done for a very good reason.
My X-fi Extreme music is a sound card. This is an instrument.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 3rd April 2009, 06:02 PM   #12
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Square waves are best generated in the analogue domain. Since (for audio) we're concerned mostly with the rise time or the flatness across the top, there's a very good way of generating suitable waves. Use a mercury-wetted relay switched at mains frequency to direct a floating DC supply to the output terminals. You can now use a 10 turn wirewound pot (with dial) to adjust the DC voltage of the (regulated supply), giving you a very accurately calibrated square wave with a rise time in ps (picoseconds). Definitely good enough for audio. The fact that it can only repeat at mains frequency isn't a problem because we look at the edge for HF and the top for LF.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 3rd April 2009, 06:35 PM   #13
jackinnj's Avatar
Scott Wurcer chimed in on this thread:
Can we improve this low distortion sine oscillator ?
there's a link to an EDN article to be found.
I built the "Eager Oscillator" (paen to Dale Eagar who wrote the Linear Tech Application Note) -- aka "Uber Oscillator" and describe it here:
http://www.tech-diy.com/TestEquipmen...oscillator.htm
For ease of application, I wouldn't recommend the uberoscillator -- instead look for Bob Cordell's version of the SG-505 on his website.
Old 3rd April 2009, 09:40 PM   #14
anatech's Avatar
Hi EC8010,
I have to agree with both your points on square waves. I must admit that I'm lazy and either use my generator output, or an HP pulse generator I bought for that purpose. Your relays may in fact do a better job of creating a square wave.
The buzz let's you know it's on!
Hi Jack,
Completely forgot about the SG-505 clone, I'll have t read up on the "Eager Oscillator".
Thank you for the links!
-Chris
Old 8th September 2011, 11:51 AM   #15
mome is offline mome  Thailand
mome's Avatar
Originally Posted by geekysuavo View Post
i would have to agree with that. DDS from the PCM1704 could be paired with analog-to-digital conversion from a PCM1804 to provide a flexible analysis tool, instead of just generating pure tones... though it's basically a novelty soundcard now, lol! i'll look into it, most definitely.
~ brad.
Hi Brad,
I want you to look at this circuit.
Perhaps it is useful to you?.
Low-distortion Audio-range Oscillator using NE5532
New 200 watt Kit amp features ultra low distortion and Thermaltrak devices snoopy Solid State 56 3rd May 2010 09:42 AM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Ultra low distortion amp eicen Analog Line Level 10 26th February 2008 02:02 AM
ultra simple distortion effect apunker Instruments and Amps 14 22nd February 2005 07:04 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
Page generated in 0.09427 seconds (76.14% PHP - 23.86% MySQL) with 11 queries
