Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th May 2010, 06:49 AM   #31
Smile Urgent Digital Control
You Quoted:-
" I used HEF405X Series analog multiplexer/demultiplexers in several applications...
HEF 405X series gives 5 nano seconds propogation delay and % 0,04 distortion under 10V supply voltage.Please be realistic... Hi-Fi systems are gives us about %0.1 distortion.Be easy and use these products.
You are talking about relays for signal switching.What about RFI and EMI conditions generated by relay coil ?? .This gives a chattering on sound while switching i think..
Take a look at these links:
Detailed Datasheet (Philips)
http://ics.nxp.com/products/hef/datasheet/hef4052b.pdf
Some applications
Audio Switch Notes
MOSFET Integrated Amplifier"
I want to know can these 405X Series can Control analog singnals of 18V P-p that is VEE=-9V and VDD=9V with Digital Control Signals of 5V? Is there any way out? Please do reply at the earliest. Thanking you in advance.
Old 13th May 2010, 09:35 AM   #32
danzup is offline danzup  Romania
danzup's Avatar
Some applications
Audio Switch Notes
What EMI what RFI ??
When i select an input , that is : the relay is on and nothing more come from , as from basic physics we know that !
And about a simple Ag contact what distortion introduce in audio path ???
There are not better tube than 6P3S and 6N2P for my ears !
Old 13th May 2010, 10:13 AM   #33
Mooly's Avatar
Yes... use a level shift arrangement using perhaps a small signal FET ( eg 2n7000) The logic runs on 0 and 5 volt, so assuming 0 is the same as audio ground use the FET and high value resistor across the -/+9 vdc and use a high value resistive level shift divider from the logic to the gate of FET.
Or run the logic referenced to -9 volts... loads of possibilities.
A simulation free zone. Design it, build it, test it.
Old 13th May 2010, 01:24 PM   #34
ozangazi's Avatar
Send a message via MSN to ozangazi
Yes it's possible.Please look at this sch.
http://www.sydzdiy.com/uploads/allim...040492I4-0.jpg
Old 18th May 2010, 12:50 PM   #35
Smile Please Urgent
Respected Sir,
Thank you for the help but still one confusion, in the pic A, B are controlled by 6 - 12V Logic levels, right? Can the chip series be operated at +12 to -12V and controlled by 5V Logic Levels? Will there be no problem? Then why it is not mentioned in the datasheet? Rather it is written Logic 1 is equal to VDD? Thanking in advance for your help.
Old 29th December 2010, 12:09 PM   #36
Originally Posted by pekinin View Post
I am interested in building a audio inputs switch (audio selector). I have experience in digital circuits, but not much in analog circuits, but I am passionate about audio. So I need a little help.
Had thought of using a pair of 4051 with 8 inputs each, and also a small micro controller (atmel avr or microchip pic). It would be better to use the 4052? (I prefer to have 8 stereo inputs with two 4051, one for each channel)
Someone can recommend me any design or schematic?
I have to put a "audio buffer" or preamp? in the output? in the input? in two places? (if so, could use a NE5532?)
Any information is welcome: schematics, designs, tips, ideas... (I need help especially in the analog audio part (input or output preamplifier, buffer...)
Thanks you very much for everything!
PS: The 4051 has an acceptable quality? or make noise in the audio?
Thanks! bye!
Here is a sample 4052 used as a tape/cd interface circuit for AC DELCO car stereo. Click the image to open in full size.
CMOS multiplexer as input source switch Leolabs Parts 1 17th October 2006 10:10 AM
Home Made Tubes?? has anyone made one, is it possible?? John Biles Tubes / Valves 7 11th December 2005 01:29 AM
74hc or 74ac logic chips for digital audio ? Reina Digital Source 8 22nd July 2005 07:10 AM
Audio quality from a 4051 mux? Ayah Parts 10 13th May 2005 12:23 PM
Page generated in 0.09410 seconds (79.70% PHP - 20.30% MySQL) with 11 queries
