| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#31 | |
Hello,
1. I think the passive preamp will require a bit more input impedance than the 200 Ohms. Can we use this transformer for the purpose : Neutrik - Audio - Transformers - NTL1 ? 2. What will be the result if we use a 1:2 transformer instead of the 1:1 model ? Best regards, Bins. Quote:
#32 | |
Previously: Kuei Yang Wang
To be direct, a line input transformer that is suitable will cost nearly as much as a real TVC. In essence a TVC as I specify it, is nothing much different than a 1:1 line transformer at 10K nominal impedance, but with tapped secondary and a suitably changed winding structure. This was done as at the time really high performance 10K 1:1 line transformers where made by several manufacturers, so chances where good to convince at least one to make TVC modification. FWIW, the "Ingot" uses a Magnequest transformer, quite likely the B7 10k:10k Magnequest Products - MQ Iron Listing/Pricing Use that with P&G 10K pot: FS/Trade: Penny + Giles Ciao T |
#33 | |
The Neutrik transformers are readily available with me and that is why I had asked. I think the Neutrik NTL1 is having almost similar specifications as that of the Magnequest B7-10K:10K version. 1. What will happen if I omit the 1K fixed resistor that is added across the secondary to create an idealized constant ? Will it significantly degrade the performance ? Best regards, Bins. Quote:
#34 | ||
Ciao T |
#35 | |
The 1K resistor is shown at the output end after the pot. What is the best value for the log pot (Is there any specific reason for using the 10K version) ? Best regards, Bins. Quote:
#36 |
Yes. And next to it it says "to bass amp". So why do you claim that this resistor: " is added across the secondary to create an idealized constant ? " when it clearly is not added across the secondary first of all, never mind the rest? The value that matches the transformer of course. The secondary winding of the transformer in your drawing is 10K impedance. Plus, there are the usual considerations for "passive pre-amplifiers", which pretty much dictate a 1K pot to be desirable (but few sources sound good driving such a load) and a 10K as the upper end of the value range, to ensure reasonably wide system compatibility. Please forgive, but many of your questions seem incredibly naive. Would you mind finding yourself a good book on audio electronics and actually reading it? It would inform you much better than this "q & a" game you are playing here. Second, given your current level of knowledge I think what you are trying to do is a fools errand. If you are absolutely bent on doing it anyway, good luck. If so, take my suggestion and use the original transformer of the device you want to copy, or look for Sy's heretical linestage and use the Jensen Transformer he used. I suspect either will be largely redundant though, depending on the rest of your system. The Neutrik Transformers may be best described as "functional, of sorts". Second, have a look at Nelson Pass's B1 Preamplifier, this kind of buffer is a very good idea to use after a higher impedance potentiometer to overcome some of the limitations of traditional "passive pre-amplifiers". FWIW, Steve McCormack's most recent passive preamplifier uses such a buffer potentiometers and transformers to make a device that has certainly be reviewed very well. Ciao T |
| Phase Linear 700 input section question | taj | Solid State | 1 | 10th July 2009 05:24 PM |
| passive I/V and transformer | D.A.R.R.Y.L. | Digital Source | 12 | 1st May 2006 10:42 AM |
| passive I/V directly into transformer ? | Bernhard | Digital Source | 6 | 17th August 2005 08:39 PM |
| PAssive preamplifier (volume attenuator) with Aleph 2? | vmajor | Pass Labs | 5 | 5th February 2005 06:03 PM |
| passive preamplifier newbie question | Jamh | Solid State | 3 | 2nd December 2003 05:38 PM |
| Page generated in 0.12334 seconds (81.74% PHP - 18.26% MySQL) with 11 queries |
