Few questions about Linkwitz' mic amp circuit
Old 8th February 2009, 06:20 AM   #11
454Casull is offline 454Casull  Canada
If low ESR is optimal, should I parallel two 120 uF caps?
I think 25V caps should work here...
Old 8th February 2009, 06:27 AM   #12
TheSeekerr is offline TheSeekerr  Australia
If you aren't short of space, that's a perfectly good solution, just get them as close to each other as possible.
25V would be fine.
Old 8th February 2009, 06:52 AM   #13
Thanks for your help. It's greatly appreciated.
Old 8th February 2009, 10:49 AM   #14
infinia is offline infinia  United States
infinia's Avatar
Default Keep it simple
I wouldn't worry too much about batteries being unbalanced in that preamp circuit. Starting with fresh batteries the current draw is balanced so....not a problem here as with some other circuits. The opamp can deal with uneq V's esp with the output being very low swing (tens of mV). it's really a non issue.
Just use 2 batteries and add the ceramic 0.1uF caps (generic, not NPO)
OT comments below
Dielectric microphonics for supply bypassing not an issue esp with microphones in use. Caps used in a high gain, high impedance feedback network would be a concern tho. Then I would use film instead of NPO for anything larger than 500pF due to cost.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 8th February 2009, 05:17 PM   #15
Default Re: Keep it simple
Crud. I already soldered MKTs to the legs.
What will the difference be? I've got to do some parts shopping anyway.
Old 9th February 2009, 03:34 AM   #16
infinia's Avatar
MKT should be OK for bypasses. Here close placement is a little more important than dielectric type. I just prefer ceramic bypass caps because they are smaller for a given value and offer a lower impedance at MHz, where the opamp errant oscillations tend to occur.
Old 9th February 2009, 04:59 AM   #17
Well, I'm open to replacing them. I want this thing to give me great sound right when I power it up.
Old 9th February 2009, 01:16 PM   #18
infinia's Avatar
Default these arn't that critical sound wise
This is a for speaker test rig right. Should be ok for recording but with selectable gains maybe.
MKT you are using is OK
AVX box caps 0.1u 10% 50V or similar. (post your complete PL before clicking buy if you are worried)
Old 9th February 2009, 01:30 PM   #19
I'm actually hoping to use this for recording as well as for speaker testing.
I've bought most of the parts already; I can supply a list when I get home.
Old 9th February 2009, 02:49 PM   #20
All resistors are 1% metal film
OPA2134PA op-amp
Input (?) polar cap is a general-purpose tantalum
Op-amp power supply decouplers are currently 0.1 uF MKT box caps
Few questions about Linkwitz' mic amp circuitHide this!Advertise here!
Linkwitz Transform Circuit skogs Subwoofers 1 26th October 2006 11:03 PM
Linkwitz transform circuit? Dxvideo Subwoofers 5 30th August 2005 02:20 PM
Linkwitz eq circuit The Dudster Subwoofers 5 3rd November 2004 05:29 PM
Linkwitz lm3886 circuit srfranci Chip Amps 1 30th October 2004 11:28 AM
linkwitz transform circuit pkgum Multi-Way 8 14th December 2001 12:08 PM
Copyright ©1999-2017 diyAudio
