| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
hello
I was wondering, is it possible to make an active filter with 'normal' components? I mean a bufferstage, then some coils/caps/etc... and then another bufferstage. So coils/caps can be very smal and no interference from the speakers themselfs and therfore a better and simpler design. And also less opamps in signalpath. Is it a stupid thought and/or are there any items here on diyaudio? Thanks!
I hate carryable |
#2 |
This is a classic:
http://www.neilmcbride.co.uk/naxocircuits.html (terrible schematics but correct...rewrite if you don't understand) and you dont even need coils.....
#3 |
Yes, easily. here is a link to John Broskie's Tubecad article which describes how to do it with tubes as cathode followers. Substitute JFETs as source followers and you're away. Nice software too for small $.
Broskie - Tube Based Xovers |
#4 |
Yes, and it is widely done in the past. A second order Sallen-Key filter only needs a 1x buffer as the active component. And that is exactly what an emitter c.q. cathode follower is.
http://en.wikipedia.org/wiki/Sallen_Key_filter |
#5 |
the unity-gain Sallen-Key topology simply relies on an active element with gain 1. It sounds rather weird to me to use OPs with their complex internal structure and OL-gains in the millions what a simple buffer would do anyway, because of its nature! So you can use a simple transistor-buffer in emitter- or sourcefollower mode. Instead of the emitter/source-resistance I´d opt for a simple transistorized constant-current-source. Have a look at Erno Borbely´s articles about simple SE-JFET-stages. Imho You can´t get any better sonically than that. jauu Calvin |
#6 |
thanks all,
I now know what to search for. But more info is always welcome
I hate carryable |
| Replacement opamps for active crossover? | xephon | Parts | 4 | 15th December 2007 12:02 PM |
| active filter from rod elliot and sub filter questions | wuffer | Parts | 0 | 2nd October 2005 01:12 PM |
| Active crossovers - opamps vs DSP | Zodiac | Multi-Way | 42 | 29th April 2005 06:55 AM |
| Opamps for active crossover/filter | harvardian | Solid State | 10 | 3rd January 2002 02:01 AM |
