| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Anybody knows what Opamp sits in this phono board ? I've got the board years ago ,burned out Opamps
TIA, L |
#2 |
Probably 5532 (single) or 5534 (dual). Trace the circuit to see. Otherwise, power it up without opamps and check on which pins you find the PSU + and - voltage, this will tell you dual or single as the pin outs differ.
Good luck |
#3 |
hallo!
when top view: 5532 is the dual version(pin 8 =v+,pin7=output).5534 is single(pin 7 =v+,pin6=out). regards........... |
#5 |
Thank you Gents!
Its a single NE5534AN per channel (for MM version) .The Board looks very simple .Opamp is coupled with 0.33uF to output. I'm not sure Opamp change would bring any improvement .I'm going to build some decent PSU and make it stand alone unit. Regards, L |
#6 | |
I quite like LT1468 in phono for eg. A more dynamic sound then NE but not as dry a sound as the AD chips for eg. Not lush like BB. |
#7 |
hallo.
the lt1028 (linear technology) could be annother choice. greetings..... |
| Exposure 2010 No Power Supply | ANDYLASER | Solid State | 4 | 6th June 2011 04:03 PM |
| folded-cascode FET/opamp MC phono | Werner | Analogue Source | 33 | 17th January 2010 10:22 AM |
| Replacing Dead Phono Opamp...What to Use?? | EchoWars | Solid State | 33 | 9th January 2010 06:41 PM |
| Wanted: MOX Discrete opamp board | JohanH | Swap Meet | 10 | 22nd August 2006 06:51 AM |
| Circuit board for phono pre-amp | peterb | Analogue Source | 1 | 4th February 2004 04:56 PM |
| Page generated in 0.08905 seconds (78.22% PHP - 21.78% MySQL) with 11 queries |
