Go Back   Home > Forums > Source & Line > Analog Line Level
Old 8th October 2008, 07:43 PM   #1
dead rat's Avatar
Question output standard?
hellooo
Do CD players, mp3 players, radios etc. follow some international standard on output voltage level? like 2V rms?
If one such standard exist please lnik to it
Old 9th October 2008, 04:38 AM   #2
Technically, for an output to be "line level", it should be -10dBV as referenced against a 1 volt RMS sine wave, ie. it should be 0.1V RMS or 0.141V peak.
For professional gear, "line level" is nominally +4dBU as referenced against a 0.775 volt RMS sine wave, or 1.228 V RMS.
In practice, very few items of consumer equipment follow this standard, and it's hardly uncommon for professional gear to to ignore it too.
As a result, it's common practice to design input stages to be able to handle up to 5V RMS, just to be sure.
Old 9th October 2008, 07:34 AM   #3
Ghianni is offline Ghianni  Greece
Well, there is an IEC (International Electrotechnical Commission) standard under "Publication 268-15" which states that the Line output would have a Normal working output voltage of 1.95Vrms (+8 dB ref 0.775Vrms). May be a new revision exists of this Publication.
Old 9th October 2008, 05:19 PM   #4
kevinkr's Avatar
Philips/Sony Redbook (supposedly?) stipulates a level of 2Vrms for 0dBFS, and this has become the defacto standard for consumer digital electronics (non portable electronics) in most markets.
Some information (not complete) here: http://en.wikipedia.org/wiki/Red_Book_(audio_CD_standard)
The output voltage is stipulated somewhere in this document, (IIRC) unfortunately I have not been able to find an excerpt on line that actually shows this.
www.kta-hifi.net
Old 9th October 2008, 05:54 PM   #5
Frank Berry's Avatar
This is how I understand the specification as well.
2Vrms is at absolute clipping. Allowing for 13dB to 15dB headroom, that would put the "normal" output voltage somewhere near .4Vrms.
Frank
Using a standard pentode-tetrode as output "space-charge tube" any ideas-experiences? bembel Tubes / Valves 12 11th March 2010 05:56 AM
Replacing a standard output transistor with a Darlington EchoWars Solid State 9 25th January 2008 02:12 PM
Non-standard rackmount Nixie Parts 5 13th October 2006 01:29 AM
Standard output specs of sources and preamps and help with stability theory jteef Solid State 2 1st October 2001 12:22 AM
Page generated in 0.07742 seconds (75.31% PHP - 24.69% MySQL) with 10 queries
