Juicy Music Tercel
Juicy Music Tercel
Old 3rd October 2008, 07:14 PM   #1
seanzozo is offline seanzozo  United States
Default Juicy Music Tercel
I just finished building the new Juicy Music Tercel. It is a dead simple kit to put together, an IMHO a great deal. You populate a board, connect the board to the back panel and you are good to go.
I figured I would give y'all a photo of the board, an installed photo, and a frequency response measurement I took. For photos of what the assembled kit looks like from the outside (I have the maple base):
http://www.juicymusicaudio.com/tercel.htm
Right now a Rega P2/Shure v15-III (MR stylus) is connected to the Tercel spinning Lou Reed's Transformer. The Tercel drives a pair of Triode Wired Dynaco MK-IV based amps which run a pair of open baffles with a Fostex FX120/Eminence Alpha 15's.
Solid imaging and very smooth, still experimenting with cartridge loading.
Sean
Old 3rd October 2008, 07:15 PM   #2
Installed
Old 3rd October 2008, 07:17 PM   #3
Frequency response - pretty much perfect RIAA
Only one channel is on the graph, both channels had essentially identical RIAA. Channel to channel overall gain difference was 0.7db.
Old 3rd October 2008, 07:50 PM   #4
And a picture of the room
Old 7th October 2008, 04:10 PM   #5
kevinkr's Avatar
Juicy Music Tercel
Cool.. I particularly like the OB speaker system...
FWIW: As an aside the coupling caps on the Tercel look a lot like current CDE WMF types - not in my experience the last word in transparency.. You might want to try some surplus Russian teflon types (or similar, like Rel TFT or VH Vcaps) - you might be surprised at the difference. (I was) Looks well put together and nicely soldered.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 8th October 2008, 04:01 AM   #6
Thanks for your compliments. The OB's are fairly enjoyable, it is kind of a shame that they have relegated speakers that took a lot more effort to build to the other room. I probably need a sub or three at some point to handle sub 45hz.
I have thought about new caps for the coupling caps. As is likely clear from the image, orange drops are used in the RIAA. The coupling caps are a mystery to me they are marked "150 M" and are some kind of 250V film. The large one is a 1 uF that is ~30mm*12mm (larger than the equivalent 250V Solen MP). Does anyone know who made these caps.
I know Mark (of JuicyMusic) uses Auricaps in this phono stage when it is the integral stage in the Blueberry so I might try those, although I have some Rel PPFMXS in the dynas that I like. Thanks again for the suggestions.
Sean
Juicy Music TercelHide this!Advertise here!
10-25 hz, is it necessary for HT or Music? Daveis Subwoofers 236 26th October 2008 02:31 AM
music from PC Antonio Tucci Digital Source 20 5th June 2007 01:27 AM
need help with music sub epalla Subwoofers 17 7th July 2006 02:21 AM
Music Les Music 6 24th August 2003 05:01 PM
JE Labs 300b round 5. MUSIC!! MUSIC!! TubeHound Tubes / Valves 14 11th January 2003 12:02 AM
