2 sources into 1 Stereo - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 23rd September 2008, 11:46 PM   #1
Default 2 sources into 1 Stereo
Hi everyone,
I have a Stereo system with an AUX connection (Red & White RCA female) that I plug my desktop computers audio into with a 3.5mm-to-RCA audio Y-cable. Now I got myself a laptop and I'd like to hear the audio from the laptop AT THE SAME TIME as I hear the audio from the desktop through this stereo.
I tried just simply joining the two 3.5mm outputs from the 2 computers together with a 3.5mm Y-connector and then connected that with a 3.5mm-to-RCA audio Y-cable to the stereo's AUX but the volume just got really soft and didn't work properly.
Is there a simple connector I can get (like 3.5mm cable with a diode?) or something similar that anybody has heard of that I can buy for cheap?
Do you know why this doesn't work with the setup I explained? What's going on here to prevent that from working (be as technical as you can in your explanation)?
Thanks for the help guys!
-Mike
Old 24th September 2008, 01:34 AM   #2
Default You need a mixer
You can use resistors and make a passive mixer. Google "passive mixer circuits".
Old 24th September 2008, 07:07 AM   #3
YOU'RE THE MAN!
Ya I found a bunch of cool sites like this 1 http://www.tkk.fi/Misc/Electronics/c...s/linesum.html and this 1 http://www.epanorama.net/circuits/linemixer.html . I guess I could build this myself but I'd rather buy this pre-made... any ideas where I could find something like this pre-made for cheap?
-Mike
Old 24th September 2008, 01:25 PM   #4
diyAudio Member RIP
http://www.proacousticsusa.com/produ...l.php?pId=8492 /sreten.
Old 2nd October 2008, 02:09 PM   #5
Question Amature build (need technique advice)
Hey guys, thanks for the help!
I built this simple mixer and it really works ! My only concern is my technique, I'm not sure if I did this sort of "by the book" or if there's a better way. Like when I wanted to connect 2 adjacent holes together I just used a pool of solder... is that right? When I wanted to connect 2 holes from across the board I just used a wire under the board and adhered it at the points with loads of solder... is that right?
Anyway here's what the finished project looks like; let me know what you think...
-Mike
Old 2nd October 2008, 02:09 PM   #6
Default 2 more pix
Old 2nd October 2008, 02:17 PM   #7
diyAudio Member RIP
Most people would have done it by "hard wiring" it in the case.
That is fitting the sockets and using solid wire and the resistors.
As long as it works how does not matter much.
/sreten.
Stereo in/multiple Stereo outs Circuit MartinByrne Everything Else 3 7th May 2009 01:11 AM
Reprocessed for stereo, Rechanneled for stereo and Duophonic oldheathkitphil Analog Line Level 3 29th February 2008 01:20 PM
USA Vinyl Sources lt_texan Analogue Source 1 1st October 2007 12:21 AM
Sources of hum. JoeBob Solid State 30 19th July 2002 04:23 PM
How do I wire stereo headphones on a stereo tv? hike1 Everything Else 2 10th September 2001 02:22 AM
Copyright 1999-2017 diyAudio
