Go Back   Home > Forums > Source & Line > Analog Line Level
Old 10th September 2008, 02:20 AM   #1
azone is offline azone  United States
Default What type cable to use for double shielded driven guard?
I have an application where I have an audio input coming into a non-inverting amp with high gain adn high input impedance.
There is some capacitively coupled noise making it's way in and after being amplfied the signal-to-noise just takes a beating,
you can hear some noise/buzzing.
I have eliminated this noise by 99% by using a driven guard, where the shield is connected to the inverting input of the the
op-amp (which is ideally a the same potential as the non-inverting input). The shield at the other side of the cable, the audio
input, is left open. This works very good and is all fine and dandy but performance is improved even more if I run a second
shield and connect it to system ground at the audio input side (leave it open at the op amp input side).
My question is, as far as I know there is no such cable that has one (or more) conductors and two independent shields?
I've considered using a twisted pair cable with shield and using one of the pair as a shield but this is not ideal. IS there
such a cable that has two isolated shields?
Old 10th September 2008, 07:12 AM   #2
Calvin is offline Calvin  Germany
Calvin's Avatar
www.sommercable.com offers under ´professional studio equipment´ such a cable, the SC-Galileo 238PLUS ,order-nr: 200-0271, 3.32€/m.
Under the name ´SC-Polaris Triax 8´and ´Triax 11´ they offer a video cable with insulated double shielding (no: 600-0313, 601-0353, 601-0353, 601-0303), ~7€-11€/m.
They offer excellent cables with very affordable prices.
jauu
Calvin
Shielded input cable Rob11966 Tubes / Valves 2 14th August 2007 10:37 AM
shielded power cable rkreim Vendor's Bazaar 6 23rd March 2007 02:33 AM
shielded cable vs ribbon cable Leolabs Parts 2 23rd July 2006 05:21 PM
Shielded cable for input signal falcott Parts 2 5th September 2004 02:45 AM
Should Intercnnects & Speaker Cable be Shielded? ralph-bway Everything Else 4 5th January 2004 02:28 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
