High frequency high voltage oscillator - help!
Old 31st August 2008, 11:35 AM   #1
gentlevoice is offline gentlevoice  Denmark
Default High frequency high voltage oscillator - help!
Hi Diys,
I'm doing a high voltage high frequency oscillator for microphone experiments, however, do have a slight problem (schematic attached below).
What happens is that the cutoff frequency is around 6-7 kHz and I need to be able to generate a ~ 1000 Vpp signal at around 1 MHz and with a current of app. 3 mA.
Anybody has any suggestions for a simple schematic - or improvements to the schematic below?
Thanks!
Jesper
Old 31st August 2008, 07:44 PM   #2
Default A P.s.:
... it should be a variable frequency oscillator capable of going from e.g. 1 kHz to ~ 1 MHz
Jesper
Old 31st August 2008, 08:59 PM   #3
bear is offline bear
expert in tautology
bear's Avatar
Rather unclear how or why a high frequency high voltage oscillator relates to microphones?
But anyhow, buy a signal generator with the required frequency range and stability, build a high voltage amplifier to be driven by the oscillator. That would be the fastest and surest way to go without having to monkey around with it.
Building a single oscillator that will a) be stable, b) go from low audio to 1mHz without switching ranges and c) have an output in the 1000vrms range is not that simple or easy. Switched ranges and you have a shot at it. Can't say that you'll get stability without some serious work though.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 31st August 2008, 09:40 PM   #4
dmills is offline dmills  United Kingdom
Your problem is that the output from your circuit is high impedance single ended, at 1Mhz it doesn't take very much shunt capacitance to kill it.
I suspect that 220K collector load when combined with Ccb and the miller effect when fed from a 15K source will comprehensively kill the gain at 1Mhz.
You really need to be applying RF techniques at these frequencies (think matching networks and RF transformers).
What impedance (not resistance) is your load? If mostly inductive or capacitive, can you make it part of a tank circuit? That way you get your voltage gain from the Q of the tank and can drive at much lower voltage wither via a tap on the inductor or via a loosely coupled primary winding of a few turns (Starts to sound like a tesla coil!).
There are some things that become very easy at RF once you start thinking in RF terms rather then audio.
Regards, Dan.
Old 31st August 2008, 10:51 PM   #5
wakibaki is offline wakibaki  United Kingdom
Banned
Are you mad?
Where are you getting 1000 volts of DC?
The transistor in your diagram is rated 250V.
You should think twice before messing with lethal voltages, and three times before asking stupid questions. Why on Earth would anyone want to have this signal around if they could possibly avoid it?
Unless perhaps you're intending building an AM or CW transmitter? In which case there are safer ways to develop that power output. Plus it would be illegal of course.
w
Old 1st September 2008, 04:00 AM   #6
ak_47_boy is offline ak_47_boy  Canada
How about a 100vpp adjustable frequency square wave generator feeding a 1:10 step up transformer. The electronics will be much easier.
Old 1st September 2008, 04:09 AM   #7
Hi!
Thanks for reading and answering
@dmills:
I will be using the circuit to find out if a "sub-plasma" microphone is feasible/possible. I.e. if high frequency conduction through air is practical for microphone purposes. Somewhat like using a plasma tweeter for a microphone but without entering the plasma state which seems to me to be noisy and also emits ozone. I reckon the impedance of the air, which is the load, will be in the range of mega ohms.
@bear: I actually do have a suitable oscillator that can go up in the MHz range. I "just" need the amplifier that can amplify the signal I usually can make my circuits stable, particularly if they are simple, so if any suggestions ???
BTW I forgot to change the transistors in the diagram - I will be using a 2SA970 for Q1 and probably a MJE18004 for Q2. Suggestions are welcome, though (for Q2 particularly).
Jesper
Old 3rd September 2008, 11:18 PM   #8
Banned
So people have been using air-spaced capacitors for years without realising they made good microphones if you apply 1000 vpp of RF. Wow! That explains so much!
w
Old 10th September 2008, 02:52 PM   #9
I don't yet know if they do
Jesper
High frequency high voltage oscillator - help!Hide this!Advertise here!
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
high frequency high voltage power supply... moray james Planars & Exotics 6 23rd July 2008 07:57 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
