Go Back   Home > Forums > Source & Line > Analog Line Level
Old 22nd July 2008, 09:36 PM   #1
Vulpine is offline Vulpine  Germany
Question AGC in FM tuners ?
Dear all,
i'm wondering why there are FM tuners with AGC in the IF chain. So far my belief was, that for FM reception you just need to amplify/limit the signal to a level that is suitable for the demodulator.
AGC ahead of the mixer would make sense to me (reduction of signal to minimize chance of overloading the mixer).
Could someone please enlighten me ?
Arnie
Old 24th July 2008, 10:28 AM   #2
owen is offline owen  United Kingdom
It prevents overloading the demodulation stages from over-strong signals - the sooner you do that after the initial gain stage the better - it provides a more conistant signal level to work around....
Owen
Old 24th July 2008, 02:17 PM   #3
Thanks Owen,
what would be the result of overloading the demodulation stages ? Audible audio distortion ?
I'm thinking of a PLL demodulator which (in theory) would only demodulate the strongest signal, IM-products shouldn't be that much of a problem then ?
cheers,
Arne
Old 29th July 2008, 10:02 AM   #4
Yup.
It would induce distortion - audible and not-so audible.
The biggest loser for a non-agc stage would be the weaker signals would simply disappear.....
Owen
Old 29th July 2008, 10:47 AM   #5
Since there is no information in the signal amplitude there is no need for AGC. You can use heaps of gain and build your IF strip in a way that it is clipped already with the antenna input shorted.
It is important that the proper signal is selected before any such nonlinear operation is made otherwise you will suffer from IM distortion.
The Revox A76 tuner for instance had an if filter with low group-delay distortion followed by such a limiting IF amplifier. Even when two competing signals are on the same frequency the one which is approx 3 dB higher will "win" and be listenable.
ftp://ftp.studer.ch/Public/Products/...A76_Serv_E.pdf
Charles
Old 29th July 2008, 11:28 AM   #6
timpert is offline timpert  Netherlands
timpert's Avatar
In the Revox A76, an AGC can be found. Look on page 29 in the service manual, there you see diode D104 configured as a rectifier to increase negative bias (which decreases gain) for G1 of Q101 with increasing amplitude of the mixer (Q102) output. It's a classic way to implement AGC.
The mixer needs an unclipped signal at a certain level to perform well, and with the large range of signal levels the receiver must handle, gain control before the mixer is required. The A76 has it in the best possible place: right at the input stage, preventing any stages further down the pipe from becoming saturated by a large input signal. The deliberate limiting by clipping of the IF signal only occurs after mixing and filtering.
Old 29th July 2008, 10:07 PM   #7
Hi all,
thank you for your valuable replies, i think i got the pciture.
cheers,
Arne
Old 4th August 2008, 02:53 PM   #8
This is right but the AGC is not needed for the demodulator as it was claimed first.
The linearity problem of the mixer could also be solved by the use of a high level mixer so you would have an FM tuner without any form of AGC.
Charles
Vintage Tuners newbie123 Analogue Source 58 13th August 2010 06:51 PM
how do tuners work ! jimbo1968 The Lounge 2 16th May 2009 12:08 PM
ITT Tuners nhuwar Analogue Source 0 5th March 2009 07:54 PM
Suggestions on tuners boostin1989 Everything Else 3 17th February 2008 02:36 PM
Recievers? Tuners? RF? DIY?? RMS Solid State 0 27th November 2002 04:49 PM
Page generated in 0.09025 seconds (77.95% PHP - 22.05% MySQL) with 10 queries
