Balanced XLR source RIAA
Old 18th July 2008, 05:39 PM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default Balanced XLR source RIAA
hello
see my idea to have perfect balanced signal
from MC cartridge
with new cable
and four channel RIAA
Old 18th July 2008, 08:58 PM   #2
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
This doesn't fill me up with confidence.
Old 18th July 2008, 09:28 PM   #3
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
indeed ...
that is a lot of components to match and there are likely more elegant and higher performance approaches available.
but, who am i to say.
give it a go and let us know how it works out ...
best regards,
mlloyd1
Old 19th July 2008, 10:15 AM   #4
Stee's Avatar
Default Balanced Source is the Way
yes sure
I will test and upgrade...
really the news is
connect MC in balanced mode
to have better performance
also for filter and other chain...
Old 19th July 2008, 11:24 AM   #5
On Hiatus
SY's Avatar
Running the cartridge balance is a very good idea (says the guy who runs his cartridge balanced). These are just not good implementations. The second one will have degraded noise performance.
There are (to my knowledge) two good ways to do it. One is to build a fully differential phono input, the other is to use a transformer at the input and run the primary balanced. The secondary can then drive the input of a conventional single-ended stage. You get 99% of the balanced advantage that way.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 19th July 2008, 11:34 AM   #6
Stee's Avatar
Default thanks <SY>
do you have a schematic of fully differential one?
http://www.esafono.it/diff.jpg
this is just a project with OPA1632
Old 19th July 2008, 11:39 AM   #7
On Hiatus
SY's Avatar
Only with tubes, but I'll bet there's a transistorized one around the forum somewhere. The "search" function is your friend.
Here's an example of a tube one:
http://www.vacuumstate.com/schematics/rtp3c_s.gif
edit: The one you linked to looks much better.
edit edit: "Better" than the first one, not better than the Vacuum State one; sorry to be ambiguous.
Old 19th July 2008, 11:44 AM   #8
analog_sa's Avatar
You can get some good, working ideas here
Old 19th July 2008, 06:30 PM   #9
Stee's Avatar
Default thesis: balancing improves
to see if the hypothesis is correct
I did a simple test that anyone can repeat at home
steps:
listen a preferred song only from one channel
for example the right channel
turn off everything
connect the left channel wire on cartridge instead of ground wire
and connect the negative pole of right loudspeaker
on left output of the amplifier
push on everything
hear the same song...
I believe the difference is very significant :
the sound is more dynamic
treble are more crystalline
the noise is reduced!
Old 19th July 2008, 06:37 PM   #10
analog_sa's Avatar
Lovely picture
It seems you are listening to the entire chain balanced now, not just the phono. Difficult to know how much of the improvement is due to the phono stage but interesting all the same. No hum?
Balanced XLR source RIAAHide this!Advertise here!
RIAA with balanced output? roger-k Chip Amps 4 1st May 2010 11:27 PM
balanced source to unbalanced amp? bays_9a5tt Pass Labs 33 9th September 2007 03:21 PM
RIAA with balanced output? roger-k Analogue Source 19 17th March 2006 04:42 PM
OPA1632 for balanced RIAA preamp.? Ultima Thule Analogue Source 1 7th June 2004 09:06 PM
Can a portable CD player be considered as a balanced source? Bricolo Solid State 10 24th December 2002 04:11 PM
