opamp hum and buzz problem - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 18th July 2008, 01:39 AM   #11
Looks like some question at ground.
Old 31st July 2008, 03:58 PM   #12
Send a message via Yahoo to agossage
I also think there is a serious ground issue. Has this problem been resolved?
Old 31st July 2008, 04:34 PM   #13
Question: What type of input coupling cap is being used? If metallized polypropylene, or something similar, with the volume up tap on the cap gently, or even just move your finger towards it. If it picks up the tapping, or starts to hum as your finger gets closer, remove the cap and reverse the leads. Then try the same test again.
Also, you mention 7812, and 7912 voltage regulators. Do they have the recommended bypass caps? What is the DC voltage feeding them?
Don Taylor
Forté 1A - buzz problem!!! lukesound Pass Labs 3 20th February 2009 09:43 AM
ground loop buzz problem SCOTT123 Solid State 3 24th March 2008 09:53 AM
Melos triode and computer as source: BUZZ BUZZ BUZZ zigo3 Tubes / Valves 4 28th November 2007 02:11 AM
buzz problem please help... hugobors Solid State 2 21st October 2006 06:32 PM
buzz problem adason Tubes / Valves 5 16th February 2006 01:17 AM
Copyright ©1999-2017 diyAudio
