Old 7th July 2008, 11:35 PM   #11
Jaimo is offline Jaimo  Canada
Default An alternate solution
I am considering the following solution for my Garrard 301 psu.
1. Generate a 30 minute 50Hz wav file using Audacity. (16 bit 44.1kHz, about 2.5MB)
2. Load the wav file into a $20 mp3 player.
3. Use the MP3 player output to drive an old Rotel RB990bx power amp.
4. Take the output from the Rotel into a step up transformer.
The MP3 volume control will adjust the output voltage and it is possible to create other wav files to do a speed change.
This looks like simplicity itself! (Almost too good to be true) My only concern id that the input resistance of the transformer is about .5 ohms and will most likely cause the Rotel to blow it's fuses. I plan on adding a series resistance to the transformer input and will fire this up tonight.
Any comments before I smoke the Rotel?
Else I will report back tomorrow
Wat se jy Mnr Flying Dutchman?
Old 7th July 2008, 11:45 PM   #12
Mark Kelly is offline Mark Kelly  Australia
You'll probably need a linear pot on the output of the MP3 player, the internal digital volume control is a bit crude to get the voltage dialled in.
You will also need to add a Zobel to the output of the amp. Try 10 ohms / 47 uF as a starting point.
If you use a T amp instead of the Rotel you can get away without the Zobel.
Toroidal step-ups appear to have far less problems than EI laminations, probably due to the lower magnetisation currents.
Old 22nd August 2008, 03:31 AM   #13
Default Rotel won't do the trick
Thanks for the t-amp tip Mark.
The Rotel amp works for about 20 mins & runs extremely hot before it's protection steps in.
I took a look around and can't find a T-amp that will give me the required 20Watts - whick T-amp are you using?
Old 23rd August 2008, 01:16 PM   #14
nicoch58 is offline nicoch58  Europe
41hz.com
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 24th April 2011 12:48 AM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 06:10 PM
need power supply advice for future power amp project. boricuaso Chip Amps 13 6th February 2008 03:24 PM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 03:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 02:30 PM
