Super Audiophile Phono-Stage - Battery Powered
Old 27th May 2008, 01:41 PM   #1
GlidingDutchman is offline GlidingDutchman  South Africa
Default Super Audiophile Phono-Stage - Battery Powered
After a disgusted failure with my attempted construction of a high quality phono stage from scratch I turned my attention, to much horror of the thing, to my Pro-Ject Phonobox II.
The Phonobox II is powered by 16v AC from a wall-wart tranny. Some audiophiles are appalled by this configuration so I thought I should for once address the "problem".
Opened up the unit and scanned around the PCB... found the two little chips (full of smoke). 79L15 & 78L15 IC regulators, which attempts to filter and smooth the half-wave AC from the single feed AC supply.
I carefully removed the two (yes only two!) diodes that divides the single phase AC current into two out-of-phase half-wave feeds. Also removed the AC input jack.
A nice cable was prepared and carefully soldered in place to feed the two regulators with < [+] [GRND] [-] > from the two 12v (-12v 0v +12v) batteries.
Wow! Am I surprised by the increase in sound quality! Look, the Phonobox II is actually a bloomin good RIAA pre-amp compared to pre-amps costing tenfold. (These days every pre-amp designer uses Op-Amps anyway... there is only a few left that has the guts to design a pre-amp using discreet components).
The sound-stage projected by the speakers suddenly has air and is almost tangible. My blasted hum is virtually gone and overall sound is inviting!
I am very pleased I took the plunge at converting the Phonobox. I wanted to do so for a long time but was scared. The tinkering with pre-amp building taught me one thing for sure - how a regulator looks and works! So there you go!
D
Old 27th May 2008, 03:32 PM   #2
despotic931 is offline despotic931  United States
despotic931's Avatar
Send a message via AIM to despotic931
Nice! Have you considered building your own diy power supply for it, or will you just leave it running off of the batteries?
-Justin
Old 27th May 2008, 03:43 PM   #3
-Justin
Justin
Luckily I have a lot of these "alarm" 12v batteries and will continue to use them. That was the idea from the start.
I will look into building a simple mains PSU for the phonostage but for now I am happy!
Sound is alive and airy! I love it!
D
Old 27th May 2008, 03:56 PM   #4
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
-Justin
Why?
The only reason that miserable thing sounds good are the batteries. Nearly impossible to get any PS/regulator to sound the same.
The "battery" sound is very impressive in immediacy, air and detal. There are some shortcomings though.
Old 27th May 2008, 04:18 PM   #5
Hello Analog SA! Have we met before?
Yes... like I said before - the sound is airy and focussed!
What shortcomings are there?
D
Old 27th May 2008, 09:48 PM   #6
d to the g is offline d to the g  United States
d to the g's Avatar
For one, you have to replace them. ie. buy new.
For two, you have to recycle them. ie. pay someone to take the old away.
If you don't do two, then please start.
Old 27th May 2008, 10:03 PM   #7
tubenut is online now tubenut  South Africa
tubenut's Avatar
Battery drawback?
Other then "green issues", dynamics for one imo/experience.
Different batteries also sound different btw...
In comparison to what reference are you calling this thing a "Super Audiophile Phono-Stage "?
It is not bad for the money in comparison to commercial options, better once some modifications are done to poor quality filter components and quite listenable but audiopile? Depends on what that means to the individual I guess.
Compares well to tenfold the price? What have you tried? For one the Clearaudio Smartphono craps all over it for say 3* the price. At ten times the price it is another ballgame all together and it is left far behind.
Guillaume
Croak Audio Exploration
Old 27th May 2008, 11:48 PM   #8
Justin
D
Ahh, the reason I ask is that I was considering purchasing a phonobox and then building a new power supply for it, But didn't want to take the battery powered route.
Why?
Batteries are a continual cost, something that will be a continual drain of my funds. These are funds that are short already, and I know these batteries are quite costly. I don't doubt that it doesn't sound way better than the stock psu, but I also believe that you could build a custom psu that would be much better as well.
-Justin
Old 28th May 2008, 07:38 AM   #9
Originally posted by tubenut
Battery drawback?
Dynamics are now better than ever as opposed to the crude AC system...
The thread name? Just to draw attention -
Yes, I am aware that there are designs that will whack it in the face but for now it sounds marvellous!
D
Old 28th May 2008, 07:43 AM   #10
Replace them how often? Every few years? Not a big deal I think...
Recycle - whats that? I live in Africa!
(Dont worry... I wont dump the used batteries on the wasteland. We have a scrap metal recycle yard here in town that recycles lead products)
D
Super Audiophile Phono-Stage - Battery PoweredHide this!Advertise here!
Battery powered op-amp analogue stage of DAC wreeve Digital Source 5 23rd August 2005 07:43 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Battery powered phono. GeirW Tubes / Valves 6 4th December 2004 07:40 PM
Battery powered Balance Line Stage icceman Pass Labs 10 26th December 2003 01:35 AM
pearl Phono stage battery option schatz Pass Labs 1 12th February 2002 03:04 AM
