Super Audiophile Phono-Stage - Battery Powered - Page 4 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 28th May 2008, 09:11 PM   #31
tubenut is offline tubenut  South Africa
tubenut's Avatar
Absolutely!
Just spotted difference 2 for the MKII, the MC/MM switch. The MK1 uses internal jumpers (that may actually be preferable).
Guillaume
Croak Audio Exploration
Old 28th May 2008, 09:18 PM   #32
I am stoooooopid when it comes to these things but will this work as a replacement for the JRC 2068D Op-Amp?
http://za.rs-online.com/web/search/s...duct&R=1823589
The price is scary for what you get!
D
Old 28th May 2008, 09:32 PM   #33
tubenut's Avatar
The signal path oppies are dual devices so you would need op275. It will work, it will be different, will it be better, probably? hmmmm expensive gamble.
Op amps can be very subjective, and which to use where is science and to some extent hard trial and error listening etc. Many would consider this knowledge/experience part of their marketable skill.
Nite nite.
Guillaume
Old 28th May 2008, 10:47 PM   #34
wildburro audio
d to the g's Avatar
Originally posted by tubenut
Compares well to tenfold the price? What have you tried? For one the Clearaudio Smartphono craps all over it for say 3* the price. At ten times the price it is another ballgame all together and it is left far behind.
I spent about $50 more for a Pass Pearl. More thump, more goosebumps. I think that the the VSPS is an excellent "budget" option. A good friend of mine just built the cheap battery version of the Hagerman and it's not too bad either. His total cost: $65
Old 29th May 2008, 06:50 AM   #35
That means you are feeding 15V regulators 12V, this would not work properly and they would certainly be starved. It probably works though because for some bizarre reason project bypassed the regulator inputs to outputs with some resistors of a few hundred ohms though I know not why...
G jou doring!
I now am starting to think this is the reason my DIY phono amp doesnt want to work... It uses the same tiny regulators!! I fed it the same dual rail 12v instead of 24v...
Today no regulator will stand!
D
Old 29th May 2008, 10:25 AM   #36
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Gliding-Cheese,
You'll pay less if you punch in AD797 on the RS link.
Life will be simpler if could decide whether you will use the phono-pre for MC or MM, if you are serious of rebuilding the phony-box.
President Dwayne Camacho says you should drink Brawndo : It's got electrolytes
Old 29th May 2008, 12:01 PM   #37
Originally posted by jacco vermeulen
Gliding-Cheese,
Jacco... okay where do I begin?
Mainly MC as I have 4 different MC cartridges at my disposal and only 1 MM...
At the moment I feel like trashing the whole Phon'y'-box cause it is driving me mad. Today, whilst changing ceramic caps I have busted & lifted two PCB track!! Makes me sizzle with anger!
I think I should rather just get a decent new phono stage or at least a pre-owned one.
D
Old 29th May 2008, 12:40 PM   #38
This sucks!!
Now I have killed the thing - it is a piece of crap!!
D
Old 29th May 2008, 09:16 PM   #39
tubenut's Avatar
This sucks!!
D
Should maybe have read: Now I have killed the thing - my non teperature contriolled solder station it is a piece of crap!!
The pads lift easy, I normally destroy the old component when modding, Ie have only one leg to deal with at a time.
Guillaume
Old 29th May 2008, 09:49 PM   #40
You said it!
I have a run-off-the-mill Weller soldering iron - temprature controller? Whats that?
Will have to invest in one...
D
Battery powered op-amp analogue stage of DAC wreeve Digital Source 5 23rd August 2005 08:43 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 07:41 AM
Battery powered phono. GeirW Tubes / Valves 6 4th December 2004 08:40 PM
Battery powered Balance Line Stage icceman Pass Labs 10 26th December 2003 02:35 AM
pearl Phono stage battery option schatz Pass Labs 1 12th February 2002 04:04 AM
Copyright ©1999-2017 diyAudio
