Looking for Balanced attenuator ideas
Old 27th May 2008, 10:07 AM   #1
cartman is offline cartman
cartman's Avatar
Send a message via ICQ to cartman
Default Looking for Balanced attenuator ideas
Hi Guys,
please help me in finding schematics for balanced volume attenuator.
Thanks!
Old 27th May 2008, 10:41 AM   #2
cartman's Avatar
is it working? (attachment)
Old 27th May 2008, 11:22 AM   #3
Dan2 is offline Dan2  South Africa
to my understanding, a balanced line has 2 signals, exactly the same but out of phase by 180deg, so that any common interference is regected by the amp
cartman, if that doesn't work im sure a stereo pot (dual pot) on the hot and cold lines should work.
Old 27th May 2008, 01:35 PM   #4
cartman's Avatar
Do you mean this? (attachment)
...by the way, this is not logical/likeable for me, because in this case I loose the "Ground independence"
What do you think?
Old 27th May 2008, 07:28 PM   #5
forr is offline forr  France
forr's Avatar
Hi Cartman,
A variation of your first drawing is the inclusion of two identical precision resistors in the signal wires and then a variable resistor between their ends, no reference to ground. It is used, I think, by Morgan Jones and Erno Boberly.
However, according to D. Self who designed mixers, your second design is to be the prefered one (the pots are supposed well matched) because it has a better common mode rejection. Common mode voltages are not rejected by the first solution.
Old 27th May 2008, 07:41 PM   #6
cartman's Avatar
Thanks Forr for you reply...
by the way, I would like to build a passive balanced preamp with my just stereo (dual) stepped ladder 10K attenuator....
What is the best solution?
Which benefit is the more important?
1) "no reference to ground"
2) "Common Mode Voltage Rejection"
As I know, the balanced signal is great why there is independence of ground. Is it true?
Old 28th May 2008, 02:26 PM   #7
as far as i know, common mode signals (interference) are usually a problem with very long wires, so if you put the attenuator pretty close to the amp (mixer) it should be ok.
i have never put an attenuator on a balanced line so i can't really help too much more
Old 28th May 2008, 02:36 PM   #8
R.I.P.
That is not possible without input and ouput transformers.
/sreten.
Old 28th May 2008, 07:40 PM   #9
cartman's Avatar
Thanks Dan2!
Old 28th May 2008, 07:42 PM   #10
cartman's Avatar
/sreten.
Thanks Sreten!
...and if I would have 2pcs stepped ladder 10K attenuators? (1 dual per each channel) can I use it? (w/o transformer)
If so, how I can connect?
thx!
Looking for Balanced attenuator ideasHide this!Advertise here!
DACT 10K Balanced Attenuator hifimaker Swap Meet 1 3rd January 2009 06:38 PM
H Type Balanced Attenuator. GeeVee Pass Labs 24 17th July 2008 06:39 PM
WTB: Balanced attenuator and switch folkeb Swap Meet 0 25th May 2006 04:33 PM
attenuator balanced 600/600 alexidoia Parts 2 13th February 2006 08:38 PM
BOSOZ Balanced Attenuator Set-up hifimaker Pass Labs 5 2nd February 2005 03:25 AM
