| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
I've got four Raunland Mic input trannies I'd like to try as SUT's. I don't know anything about them, but I figure it is worth a shot. There is no diagram on the units, but I have them in an amp, so I drew out a schematic. I don't have a way to scan it. So, here is what I found:
XLR pin 1 --- tranny pin 1 ---- amp ground XLR pin 2 --- switch Switch pos. “high” = grid of 12AX7 via .47uf cap Switch pos. “low” = XLR pin 2 to pin 3 of tranny and tranny pin 7 to grid of 12AX7 (via cap) XLR pin 3 to tranny pin 5 Tranny pin 4 connected to tranny pin 1 via .47uf cap Also connected to grid of 12AX7 via a resistor Tranny pin 6 is tied to 4 via a resistor and a weird jack marked “RC” SUT wiring guesses: Pin 1 = - input and output Pin 3 = input + Pin 7 = output + But what do I do with 5, tie it to 3? And is 4 tied to the ouput -? Any help would be appreciated. Otherwise I'm going to wire it up somehow and hope nothing breaks. pj |
#2 |
Pic:
#3 |
Hopefully you can see it, but the XLR pin 1 is the big black wire, pin 3 is yellow, and pin 2 runs straight down to the center near terminal on the switch.
pj |
#4 |
Revised Guess (I plan to try later if nobody sets me straight):
Pin 1 Ground (from TT) Pin 3 + in Pin 5 - out Pin 4 - out tied to Pin 1 Pin 7 + out pj |
| Wiring HT2 MTM | ZoZat | Multi-Way | 4 | 15th May 2009 09:17 PM |
| Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... | thomgun_lc | Chip Amps | 38 | 31st August 2005 02:46 PM |
| I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) | Audiophilenoob | Chip Amps | 9 | 16th August 2005 04:37 AM |
| Page generated in 0.07556 seconds (71.59% PHP - 28.41% MySQL) with 11 queries |
