Looking a schematic for Electrocompaniet ECI4 - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 7th May 2008, 04:30 PM   #11
tubenut is offline tubenut  South Africa
tubenut's Avatar
Could you tell me across which points to measure this DC and what value pot am I looking for on an ECI3 to reduce the level to the lowest possible? What is realisticly low?
Is there an adjustment per channel, perhaps even per "phase"?
Much obliged.
Guillaume
Croak Audio Exploration
Old 7th May 2008, 06:19 PM   #12
Measure the DC over P1 and P2, P3 and P4, respectively. It should be as close to 0VDC as humanly possible. Within a few mVs. The pot in question should be close. It is 200R. You could possibly exchange it for 100R, but then you would have to add 100R to the resistor connectet to the pots wiper. Normal value 1K3, new value 1K4, as not to upset the DC operating point, and input stage current.Ok?
Roar
Old 7th May 2008, 07:18 PM   #13
tubenut's Avatar
Thank you Roar, I will have a look at that.
Excuse my ignorance, will changing the discussed resistor/pot values reduce the DC potential present on the volume pot? That sounds smart....
Guillaume
Old 7th May 2008, 07:32 PM   #14
The value of 200R/1K3 help cater for differing Hfe in the input transistors. If they are matched, the pot can be significant lower in value, and the resultant DC imbalance will be reduced.
Roar
Old 5th November 2008, 12:20 PM   #15
Hi
Im alsow looking the schematic for Electrocompaniet ECI4.
Can someone help me with getting it?
Old 5th November 2008, 04:14 PM   #16
What seems to be the problem?
Roar
Old 6th November 2008, 02:16 PM   #17
When powering up the main fuse blow.
hehe1337
Old 6th November 2008, 03:45 PM   #18
If that is the your most accurate description you are able to come up with, then you need a technician, not a schematic.
Roar
Old 8th November 2008, 05:00 PM   #19
I opend the amp today. It smelles like burnd transformer. I try to measure the transformer and my Fluke showed 3 Ohm.
Old 8th November 2008, 07:05 PM   #20
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
I'm not familiar with your amp but :
if you can - disconnect everything from PSU ( are there fuses after graetz and cap bank ?)
put new mains fuse
power it up ; if transformer is toasted ( not likely - 3 ohms is pretty usual for any decent xformer) , it will burn that fuse again
in that case - send amp to some capable technician ;
dunno - Roar is near you , maybe he can help you more ....
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Electrocompaniet Help Andypairo Solid State 72 3rd December 2015 03:25 PM
Electrocompaniet ECI-4??? kimschips Solid State 18 4th February 2015 03:46 AM
Hello from an Electrocompaniet Fan PrimeCase Introductions 10 25th September 2012 01:17 PM
Electrocompaniet AW 250 AMP. hogue Solid State 1 1st March 2004 05:48 AM
Copyright 1999-2017 diyAudio
