Max spl of electret capsule
Old 8th January 2008, 12:24 AM   #21
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Originally posted by Charles Hansen
Who knows how much the OP is willing to spend on such a project? I assumed not very much, since his starting point was trying to use $2 electrets.
That's right. The project is only very whimsical. I don't even know when I am going to the races next - haven't been for about 3 or 4 years.
Practically every time you see a video of a top fuel car running it is just a mass of distortion. It is often loud enough to upset the focus and tracking of some analog video cameras. When you are there live, even with your fingers completely blocking off your ears the sound level pushes your ears well into the non nonlinear zone. I just want to hear what theses things sound like for real.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 8th January 2008, 01:32 AM   #22
cuibono is offline cuibono  United States
cuibono's Avatar
why not just back off if the dB SPL is too high?
here is the link to the linkwitz mic - he says it'll swing 5Vpp with 141dB SPL in.
http://linkwitzlab.com/sys_test.htm#Mic
Old 8th January 2008, 05:40 PM   #23
PigletsDad is offline PigletsDad  United Kingdom
PigletsDad's Avatar
Distance is your friend.
Inverse square law will get the level down to one that is easily recorded.
If it is 153dB at 1m, at 10m it should be 133dB and at 100m down to 103dB. Any decent mike should record that without trouble.
Old 8th January 2008, 05:59 PM   #24
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
You now need a 100m microphone cable or a very long (and expensive) lens.
Edit: I'm assuming pictures are wanted as well as sound.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 20th February 2008, 08:32 AM   #25
Circlotron's Avatar
Then the sound becomes different because of reflections and whatnot from the surrounding area. I just want to hear pure unadulterated noise, just not too noisy.
Max spl of electret capsuleHide this!Advertise here!
DIY electret microphone capsule pre-amplifier EC8010 Analogue Source 4 26th October 2010 10:03 AM
Wanted: Panasonic capsule mic Spasticteapot Swap Meet 4 7th May 2007 06:17 AM
Panasonic mic - guess the capsule...? Mos Fetish Multi-Way 4 11th September 2004 10:43 AM
Anyone have an extra electret capsule? Kilentra Swap Meet 2 3rd March 2004 05:57 AM
best way to generate Gate-Drain or Gate-Source short in electret capsule JFET? capslock Parts 2 27th September 2002 08:07 AM
