Preamp/dual source box - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 28th November 2007, 10:11 PM   #1
Wyloch is offline Wyloch  United States
Default Preamp/dual source box
So I have a B&O turntable and a Carver m500t power amp I want to use it with. Problem there is, I need a means of volume control as well as a preamp.
So I thought about searching 'round here for a basic preamp design (I'm far from an expert in DIY) using the LME49710.
Then I thought I also may want to add a CD player to this stack. So my plan is to use a three pole six terminal switch. One set of RCA inputs will go direct to the switch. The other will go to the preamp circuit, and the preamps outputs will go to the second set of terminals on the switch. Lastly, the remaing pair of terminals on the switch will go to the potentiometer.
So, now I need a recommend on a solid preamp circuit. I'd rather not buy kits if possible.
Old 28th November 2007, 10:25 PM   #2
Considering this one....
http://sound.westhost.com/project06.htm
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
First DIY job: Dual Tube Recording Preamp neoific Instruments and Amps 82 21st December 2007 04:54 PM
Audio Research Dual 75 Capacitor Source? neddyboy Tubes / Valves 7 6th April 2007 06:27 PM
Best dual opamp for preamp Jan Dupont Solid State 5 31st December 2003 08:52 AM
Copyright 1999-2017 diyAudio
