how to make a audio source selector? - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 26th November 2007, 09:02 AM   #1
no183 is offline no183  Malaysia
Default how to make a audio source selector?
hi to all firstly. i have 2 computer connected just beside.. but unfortunately i have only just 1 pair of speaker, so i decided to do 1 audio source selector, mean when i dint use 1 computer, i wanna switch the speaker for another 1. i have manage to do the stuff, but the problem is, the output of the sound have "echo" and the sound of singing, is very low.. just can hear the music (very loud) almost like digital d, anything i done mistake?
Old 27th November 2007, 09:12 AM   #2
diarav is offline diarav  India
no183,
Can you post what you exactly did? some schematic,layout etc.,
Din
Old 27th November 2007, 02:00 PM   #3
the diagram as attach below.. but wat i get is the sound very poor, ( have echo, only small song lyric hear,like in karaokae mode) i duno did i done something wrong.
Old 27th November 2007, 02:34 PM   #4
tade is offline tade  United States
Send a message via AIM to tade
on side must be out of phase. What that means is that the + and - should be switched. Usually vocals are mic'ed with one mic only. This makes the vocal track usually mono, and mono signals cancel nicely when the sources are out of phase. Musical instuments on the other hand are often recorded stereo and/or are panned to the left or right to provide a soundstage. These components will not cancel well when they meet out of phase. This provides the karaoke effect which can be desireable in certain circumstances. Not here of course.
double check your wiring. Also, you have posted more of a block diagram. if you could post a more detailed schematic i bet the problem will be obvious.
Good luck
Old 27th November 2007, 07:37 PM   #5
here sum of the pic
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Old 27th November 2007, 07:37 PM   #6
oh yea, 1 more, the earth(common) for the jack, i dint solder on the board because i thought it dont needed?
Old 27th November 2007, 08:19 PM   #7
Craig405's Avatar
thats the problem, you need to switch the earths over aswell as the signal or it will sound funny and quite likely quite!
This should be easy enough to add on if your switch has enough connections to accomodate 2 more wires to switch.
the signal needs a reference.
Old 28th November 2007, 11:36 AM   #8
may try tomorow, anyways thxs for advice
Stereo source selector IC speakerguy79 Parts 4 29th November 2008 01:16 AM
source selector mnr102 Multi-Way 0 24th February 2008 11:11 PM
To make Speaker Selector with Remocon yangsmm Parts 0 3rd October 2006 03:50 PM
Here's a source selector DragonMaster Everything Else 0 7th August 2005 03:52 AM
Preamp Source Selector Brownlow Solid State 0 28th June 2002 01:32 PM
Copyright 1999-2017 diyAudio
