audio/power/control over cat5? audio/power/control over cat5? - diyAudio
Old 23rd November 2007, 07:57 PM   #1
cbriere is offline cbriere  Canada
Default audio/power/control over cat5?
I need help to understand this,
Some audio distribution systems have the power in the wall plate,
they can provide 15W to the room speakers.
Also there is an DATA communication for Remote control.
does anybody knows how does it work?how it is wired?
cat-5 being a 4 pair AWG24 wire:
audio left&right takes 2 pair, differential
Power need 2 pair also to go to 250feet and carry
no more wires left for data?
Old 23rd November 2007, 08:11 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Possibly a single shared ground wire? That then leaves 2 wires for left and right, 1 wire for power and 1 wire for data.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 25th November 2007, 03:00 AM   #3
Nanook is offline Nanook  Canada
Nanook's Avatar
Default check the building codes...
both the Canada Hosing Standards and any provincial and local codes as well. Cat 5 is network cable. Use proper solid core for power wiring. Cat 5 does make good interconnects and speaker cable , and I'm sure the current and voltage would be suitably low enough so as to not cause any problems.
stew
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 26th November 2007, 04:17 PM   #4
Did it Himself
I'm assuming the power wiring was less than 40 volts, just to power the thing putting out 15 watts.
Old 26th November 2007, 04:34 PM   #5
Could the power referred to be the signal from the power amp?
That would need just two pair for the 15W +15W.
still leaving one pair for data and one pair spare.
40Vpk gives 100W into 8r0. It's safe to assume that DC power will be below 40Vdc for the 15W if a local amplifier needs a remote PSU.
regards Andrew T.
Sent from my desktop computer using a keyboard
audio/power/control over cat5?Hide this!Advertise here!
Line level audio over CAT5 mpkayeuk Everything Else 29 27th October 2011 02:37 AM
AV IR over Cat5 (simple audio/video repeater for Sky, Digital Tv and Tape recorder) audiodesign Solid State 0 24th June 2009 01:28 PM
audio control c-101 manual?? j_dunavin Everything Else 1 28th July 2007 05:52 PM
audio control series II eqx will not power up 02ss Car Audio 4 18th July 2007 04:08 AM
Audio Control EQX santa Swap Meet 0 5th May 2003 12:40 AM
Copyright ©1999-2017 diyAudio
