Designing a phono pre. #1: high gain block
Old 5th November 2007, 11:08 AM   #1
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Default Designing a phono pre. #1: high gain block
over the last three years, I read a lot in several forums, posted questions and build several phono pre's or parts of it and simulated some pre's as well.
There is a lot of debate of low noise, good psu, riaa network accuracy or the best sounding active device. There are two issues, though, that are crucial for an outstanding performance, but are not that often discussed.
I'm talking about best ways to acutally drive a riaa network (which amount of current/slew rate do you need, should the voltage swing over the network be small or huge etc.) from a technical perspective.
But that would be my #2.
For now, I'm interested in a high gain device. Compared to the attention that people pay to a preamp that has a gain of max. 12dB this is surprsingly seldom discussed.
And if your heading for a low distortion AND open loop design, you're on your own.
People talk about the best sounding buffers, but does acutally happen if your toss an AD797 in your circuit with say 50dB gain (that may have to drive the riaa net as well)?
Given the highly regarded sk170 and the like fets, what is your favorite high gain building block?
I'm about to finish two different first stage approaches for which I have high hopes, so my main concern is the second stage in a phono pre (MC) or the first for MM.
I'm aware of the more often discussed phono pres here, but maybe there's thread that slipped me which discusses my concern
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 5th November 2007, 11:34 AM   #2
PigletsDad is offline PigletsDad  United Kingdom
PigletsDad's Avatar
Your question hides a lot of assumptions.
Before you choose an active device, you need to pick on a design topology.
There at least the following, which have been used:
1) Single gain block, EQ set in FB network.
2) Two gain blocks (second could be unity, but need not), with passive network between them.
3) Two gain blocks with passive HF between, but active FB setting LF on second.
4) Three gain blocks (well the last was a buffer), with passive EQ split between them - used in a valve design.
In principle, some of the EQ could be implemented in the FB network of the first stage of a multi-block design, but I can't bring an example of that to mind.
Note that multiple gain block designs ease the problem of getting high gain from one stage.
The other big issue is what type of cartridge you are designing for - as MC and MM are quite different challenges.
Old 5th November 2007, 11:51 AM   #3
Onvinyl's Avatar
let's assume the following:
- MC Cartridge
- first stage is present & runs at 30dB @1kHz
- is dc-coupled (with the aid of a servo) at the output
- This stage has the 2.21kHz roll-off implemented (passive)
- the whole amp may have 2 or 3 stages
- should be open loop, if at last possible. However, open loops specs should be close to what we need in the end, in terms of distortion and bandwith
- second part riaa may be active or passive
- a solid state discrete design.
- shall make use of the 2sk389/2sj109 gems I have lying around, unless there is a real good reason not to use them.
- complexity no object, IF it helps.
Rüdiger
Old 5th November 2007, 12:09 PM   #4
Hanginon is offline Hanginon  United States
You might want to check this out - should answer some of these questions.
http://www.klaus-boening.de/
Mother always said there'd be days like this, so I'm just Hanginon!
Old 5th November 2007, 12:17 PM   #5
Onvinyl's Avatar
Hi Hanginon,
in fact, I already build this circuit. It sounds good, but I have issues with it. One is, that with all this batteries you get complicated current loops. A second is, that the first stage has to feed rather big riaa caps, A third is, you have coupling caps and an output trafo. Fourth, the gain needed in the compound stage is substantial, and its tough to make it behave well.
Rüdiger
Old 5th November 2007, 12:38 PM   #6
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Rüdiger, have you seen my QSXM2 monster? The input stage be be fitted with MAT02/03 or JFET's. Lot's of tweak potential.
The basic idea is a non-inverting preamp + inverting RIAA stage.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 55 pcb's in order. 49 paid.
Old 5th November 2007, 12:54 PM   #7
Onvinyl's Avatar
Hi P-A,
now we are talking!
I've probably seen it some years ago but did not understand. It seems I make at least slow progress, as I understand some things now...
For now, I'm referring to schematic2.
- You use a current source that feeds the cascode (T43, T45). I thought, that you need a low impedance at the base here. Am I wrong?
- What exactly is T49 doing and how does it work?
Rüdiger
Old 5th November 2007, 07:38 PM   #8
Onvinyl's Avatar
Default Some input...
Here is a sketch.
With values shown, gain sims 25dB without the (indicative only) riaa network. Bandwith sims (without riaa) some frightening 25Mhz (-3dB). Gulp.
Please don't hesitate to comment.
Rüdiger
Old 5th November 2007, 11:11 PM   #9
Gordy is offline Gordy  United Kingdom
(Sideline information: )
Also used in the Hagtech Bugle:
http://www.hagtech.com/images/bugleschem.gif
(back to the thread...)
Old 6th November 2007, 04:08 AM   #10
peranders's Avatar
It's a plain cascode, increasing the speed, lowering the distortion.
It's an emitter follower, less capacitve load to the first stage => increased speed
Designing a phono pre. #1: high gain blockHide this!Advertise here!
Phono levels and gain jnb Analogue Source 9 15th June 2007 05:23 AM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 01:26 AM
Need help designing high-gain amp circuit! electec Chip Amps 2 13th November 2003 01:01 AM
Designing a phono stage Brownlow Solid State 15 3rd May 2001 02:21 PM
