Go Back   Home > Forums > Source & Line > Analog Line Level
Old 2nd November 2007, 11:57 AM   #21
Alex M is offline Alex M  United Kingdom
Originally posted by borges
That looks like a nice place to start! However, I would probably drop the passive filter and opamp after the follower. Do you know if the follower itself has the ability to drive a line output?
Borge
I am intending to use only the "SLCF" part of the circuit on Pedja's site, as I think the filter was found necessary for the amplifier chip.
The output impedance of a simple source follower is is approximately 1/gm, or about 40 ohms for a2SK170, which is pretty low in this context .
Alex
Direct-coupled cathode/source follower driver in PP? ray_moth Tubes / Valves 83 17th July 2008 02:53 AM
Schematic please? SRPP with current source cathode follower riotubes Tubes / Valves 0 7th January 2007 05:18 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
Complex Emitter follower Banfi T. Solid State 104 1st April 2003 10:05 PM
Common-cathode triode vs source-follower Hexfet. Circlotron Analogue Source 14 22nd March 2003 07:35 AM
Page generated in 0.05763 seconds (71.44% PHP - 28.56% MySQL) with 10 queries
