Go Back   Home > Forums > Source & Line > Analog Line Level
Old 17th October 2007, 11:50 AM   #1
zhai is offline zhai  Denmark
Default questions about grounding and noise
Heys, I've "completed" 3 projects. When I started I was pretty much a beginner, so I have som design flaws that I'm now trying to rectify.
DAC: www.dddac.de , dddac1543 MK2
preamp: www.twistedpearaudio.com , kookaburra + avel lindberg trafo + darwin source selector
power amp: UcD180 stereobox, 2x UcD180, 2x UcD supply ST, 2x trafo 160VA
pictures: http://www.templar.dk/files/pics.rar
Grounding:
DAC: 220v ground pin is connected to 0v on the power supply. Not to the case.
preamp: 220v ground pin is connected only to the case.
power amp: 220v ground pin is connected to "GND" on both power supplies. And not to the case.
All boxes have ground pins in the connectors, and so do all the cables all the way to the wall socket.
primary problem:
When I connected the DAC to my old preamp, it worked fine, no noise at all. When I connected my cd player's analogue out to the preamp, it worked fine.
But when I connected the DAC to the new preamp, it gave horrible noise. I then let the 3 projects stand still for some months, tried different power cables for the preamp, and suddenly the horrible noise that was there before all the time, had gone. I also tried using the original power cable again, with no difference. I have no idea why.
So now, when I turn the volume knob on the preamp, there's noise that stops when I stop turning. When I turn the knob to high volumes, there's a "falloff" of noise, continuing after the noise that happens while I do the actual turning of the knob.
I'm pretty confused by this, but I think it has something to do with grounding. A guess is that the 220v ground pin should be connected to both 0v in the circuit and the case? Is that correct?
Secondary problem:
When my power amp is the only thing that is turned on, I get some low noise in the speakers. I'd really like to get dead silence when I turn it on, but my design includes signal cables being too close to the trafos. Is there any way to rectify this without doing major changes to the power amp?
Grounding or RCA whining noise problem... contentryder Car Audio 9 24th February 2008 03:59 AM
Grounding & board Layout questions Valvomaniac Tubes / Valves 1 26th April 2007 03:56 AM
Grounding questions arjscott Solid State 6 20th March 2007 04:23 PM
Star Grounding Questions LHMAudio Solid State 5 12th May 2006 04:31 PM
Questions re: digital grounding echo Digital Source 33 14th October 2002 06:31 PM
Page generated in 0.05991 seconds (73.47% PHP - 26.53% MySQL) with 10 queries
