Go Back   Home > Forums > Source & Line > Analog Line Level
Old 4th October 2007, 04:44 PM   #1
cactuscowboy's Avatar
Default Need advice, build control/switch box
Here's the issue. I've got three turntables, preamp, receiver, CD player, cassette deck, 8-track, and reel-to-reel deck. I operate a business doing analog to digital transfers and I'm continually crawling behind the equipment, unplugging RCA cords and plugging them into the computer sound card as I need to switch from cassette to 8-track, etc.... It takes a lot of time and it's driving me nuts!
Ideally, what I'd have is a control box allowing me to switch:
Turntable 1 (stereo)
1. Off
2. Preamp input
3. Receiver Phono input 1
Turntable 2 (mono)
1. Off
2. Preamp input
3. Receiver Phono input 2
Turntable 3 (78 rpm)
1. Off
2. Preamp input
Preamp (output)
1. Computer soundcard input
2. Receiver Aux input
CD Player
Cassette
8-Track
Reel-To-Reel
I'd like to easily switch the output from any of these components to either of the two tape inputs (or Aux input) on the receiver, or to the Computer soundcard input.
I hope this all makes sense. I don't really use the tape decks for recording much, so I can easily plug those into the receiver for the occasional need.
I've got various 'junk' steel audio component housings that would work for housing a control box. I have basic soldering and fabrication skills. I have some experience with this sort of thing from building the preamp (Bugle Pro).
My problem is with basic design and specs for the various switches. I look through my huge Digikey catalog and my eyes glaze over. I'm lost and don't know where to start.
Questions: Is there a commercially available control box that would provide these functions? I assume not so I'm thinking of building something. Are there any educational websites offering basic advice for a DIY novice like myself who needs help? Any other suggestions?
Thanks,
Dave in Wyoming
OIIIIIIIO
Old 9th October 2007, 08:11 PM   #2
deduikertjes's Avatar
I once laid my hand on such a switch box. It uses mechanical connected switches (old fashioned radio-buttons). Works quite good but was from a Dutch or German manufacturer (Vogel).
Easy work around: Split each cable in the middle using RCA male-female connectors. have the parts of the cables with the splits lying on your workbench. You can then plug/ unplug the right equipment without crawling behind the machines.
you could even consider making an old fashioned telephone switchboard look-a-like with rca cables instead of telephone cables.
succes, MArco
Old 9th October 2007, 10:28 PM   #3
Speakerholic
Cal Weldon's Avatar
What about a mixer?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 9th October 2007, 11:48 PM   #4
Thanks for the replies.
I never thought about a mixer but I occasionally see them in thrift shops.
OIIIIIIIO
control a latching relay with one switch? peace brainerd Parts 13 8th January 2009 04:24 AM
how to remote control a rotary switch based attenuator Giordano Parts 40 29th October 2008 08:01 PM
Needs E-Caps or volume control switch? 65blkbkgt Car Audio 5 25th August 2007 05:21 AM
build rca switch for preamp signals rsstonejr Car Audio 1 12th August 2005 11:03 PM
Advice on buying the right switch? jonnyrace Parts 2 19th May 2004 09:00 PM
Page generated in 0.08324 seconds (74.23% PHP - 25.77% MySQL) with 10 queries
