Hi All...
I was just sittin' here idling away some time when outta nowhere this question pops into my brain; since I don't normally use the mute function on a LM3886, would there be any audible benefit to using an active current source instead of the usual resistor?
Any thoughts?
Mike
Any thoughts?
Mike
Hi All...
Any thoughts?
Mike
Look at
http://www.rane.com/pdf/old/ma3sch.pdf
the schematic of MA3 amplifier by Rane (Rane Corporation)
At least by straightforward simulations and thought experiments, there is no benefit to a current source on the mute pin. Having said that, I use a current source on the mute pin in my products...
for example, take a look at this assembly manual, the schematic one page from the end....Q2, D3, and R6 are a current source for the mute. But, if you look at the schematic of the LM3886 internals, it just switches an internal current source. I can't see any real difference, assuming responsible design.
http://www.updatemydynaco.com/documents/AssemblyManualRev2.08.pdf
