60 WPC Amplifier for DIY Turntable Motor Drive
Motor power for typical Turntable Motor like the 24 pole Premotec "9904 111 31813" is 1.8W. This may be the one Linn uses.
TPA3116 drives it with ease. https://www.farnell.com/datasheets/1685512.pdf
Of course you can overdimension the amp, and the transformer, by 20 times for no advantage.
The transformer is better being shielded, and/or toroidial type to minimize stray magnetic fields, with enough capability.
The L01-6362 is 24VA each, per phase and should stay nice and cool.
Get a "Killawatt" at Home Depot and measure the power draw for exact numbers.
Forsell Air Reference Hurst motor is rated for like 10W.
It is just a motor driver, you will not hear it :)
uptick, thanks for the link and your thoughts. After reading through the thread again and seeing the problems some were having with Class-D amps going into overload protection mode, I was trying to get folks experience with which of the 3 amps I mentioned would be the least troublesome. I have a Kill-O-Watt but my LP-12 has the Valhalla PS which would also consume some current and would not show just the motor current draw. The Valhalla is sick ( not quite dead yet) so I am building the SG4 as a better option than repairing it.
I haven't opened up the turntable yet but I do know the motor is 50 Hz, 110 V or 115 V so I can't power it directly from a wall outlet (60 Hz AC here in the US).
You shouldn't have a problem with any of the amps as the motor is low power and the SG4 ramps up the voltage from zero to max at start up. Previous to the ramp up, some motors would draw excessive current at start up and the amps would shut down.
You want to size the step up transformer appropriately for the motor power; the larger the xfmr, the more difficult it can be to drive. If you have a 1.8W motor, you don't need to use a 50VA xfmr, 10 or 15VA should be plenty of overhead. Also, use a xfmr with the low voltage secondary as high as possible; this will be limited by the max voltage the amp can tolerate. The reason for this is the turns ratio of the xfmr transforms the load impedance (motor) seen by the amp by a factor of the turns ratio squared. So going from a 12V secondary to a 6V secondary (turns ratio changes by 2x) increases the load seen by the amp by 4x.
When picking a secondary voltage to use, remember that the rated voltage is at full load, so a 12VAC secondary will typically produce ~15VAC with no load. This is the minimum voltage you need to apply to the secondary to get 115VAC at the primary (with no load). 15VAC is ~42VPP so it requires a 48VDC supply if using a single ended amplifier. If using a bridge amp (ie TDA7492) the output voltage is essentially doubled (but the load impedance seen by the amp is halved) so you can use a 24VDC supply to generate 15VAC.
You should be able to power the 115V AC 50Hz motor from the wall if the 4 motor wires has the requisite (~0.22uF)capacitor, and maybe some (100k) resistor.
A 50Hz motor runs faster at 60Hz which could be compensated with a different pulley, or a different freq, like the Valhalla (where the heroes goes to die:).
Looking at the schematic, the 1980's Valhalla circuit uses a 3.92MHz oscillator for 60Hz and a 3.2768MHz for 50Hz for "almost" perfect -0.303% frequency error at 60Hz, less belt-, motor-, and needle friction.
There are a few threads on Diyaudio about this power supply. High voltage semiconductors and electrolytic caps will have challenges for a long life. While these can, and should, be replaced, at least every 20 years, the speed offset and no-speed feedback makes it a dinosaur.
Back in the 80's using a transformer and a linear audio amp to drive a motor would have been a bigger deal. Today their circuit look stupid.
The LP12 is the aforementioned 1.8W Preomotek. It can be driven off the mains with a cap and resistor.
  • Valhalla schematic.pdf
Thank you Bill and uptick for the information. From the datasheet, the TPA3116D2 has a max power supply voltage input of 26 V with 24 VDC recommended. At that voltage the max output voltage is 15. To supply the 12V secondaries of the AMGIS L01-6362 with 15V, it is running right at the max specs. Bill, based on your recommendation for a 10 to 15 VA transformer, AMGIS has a 9V sec. 15VA transformer, the L01-6351, with 11.1V no-load voltage. Would this be a better choice given the low power requirement of the motor? It's also a couple of bucks cheaper to boot.
Ken
Is there a need to fuse the step up transformers? I'm not concerned about protecting the amplifier as it should shut down if over current, but, a shorted motor winding may damage the transformer. The transformers I am using are 25VA. I've tried a fuse in the common section of the motor neutral, and it does blow under a "short", but, when it blows one motor winding still has voltage on it via a pathway from the other motor and transformer winding.
Hello, I've assembled the sg4 and its display seems to light up appropriately. As for my next step in completing this motor controller, I am seeking some help identifying what amplifier and transformers I may need. Being fairly new to electronics assembly, I plan to get assistance at my local maker space so as to avoid injury. I've been looking for amps similar to the one Pyramid originally suggested, but I don't think any I've found in that price range have suitable heatsinks.
I'm including a couple of photographs of my VPI mk4 JR's Hurst 600 RPM 115VAC 10W motor and its wiring. I think it is a dual phase motor, but I'm not completely sure. Thanks for any assistance!
Yes it is a dual phase motor, and you could happily drive it with a stereo amplifier or modules, along with a couple of transformers to get the output voltage back up to 110v or so. Most people use class D amplifiers as they are a lot more efficient and don't need much/any heatsinking. The Hurst is a low power motor, and you would only need around 20VA transformers, and a couple of 60watt amps. Something like these should do the job
https://www.ebay.com/itm/323772896631
You need the extra power in the amps in order to manage the startup current into the transformers.
Reactions: 1 user
Yes, in order to optimise the motor using 2 active phases is best, though you can use a single phase supply, still using the phase capacitor.
Have a look at the ebay listing I referred to in the post above yours. A pair of those amps, powered by 24V 3A SMPS should do fine.
You don't say what voltage your motor runs at, but a couple of 20VA 12V -> motor voltage transformers are what you will need
