Those Magnificent Television Tubes
Joined 2004
Am I right that the plate (anode) are connected from the to cap?
I am delighted to know you are an experienced amp builder. Apologies, and I did not mean to offend you, but when you asked a question that should be clear to you when you look at an EL36 data sheet I was not sure if you are a complete novice, or not.
Now that I know you can look it up on the datasheet go right ahead and find the anode connection ;)
https://frank.pocnet.net/sheets/030/e/EL36.pdf
At the very beginning of production, the MULLARD company produced EL6 tubes with an OCTAL base under the name EL36. This electron is relatively rare and is the same as the EL12 electron, but with a different base. Subsequently, the PHILIPS company (which was also the owner of the MULLARD company!) made an EL36 tube intended for the horizontal deflection stage in black-and-white televisions, which was significantly different from the EL36 tube produced earlier by the MULLARD company. The high-quality and well-made new EL36 tube from PHILIPS probably encouraged them to make experiments with that tube in the output stages of audio amplifiers. As a result of these experiments there were quite a number of amplifiers intended for professional use such as public address amplifiers for bus and railway stations, subways, schools, theaters, public events, stadiums, sports halls and many other uses where relatively high acoustic power was needed with very cheap (at that time!) output tubes.
Reactions: 1 user
Thanks for your additional, enlighting informations, Davorin (y)
(y)(y)!
The amplifiers you mentioned most probably are EL6405, EL6415 and EL6425 »typewriter« series, aren't they?
Btw, the 140 watt EL6435 also should be regarded member of this series, but features an almost vertical front and four PE06/40N's as finals, which resemble QE06/50 aka 807's, but are true pentodes.
Best regards!
Right now I went away from my workbench and a 1953 SABA Lindau GWIII table radio. It had a set of 100 mA series heated tubes that I swapped for 300 mA TV tubes. Here we go:
UC92 -> PC92
UF80 -> EF80
UCH81 -> ECH81
UF41 -> EF41 with resistors 68Ω||820Ω in parallel with it's 200 mA heater
UABC80 -> PABC80
UL41 ->PL82 (had also change the socket, of course)
UM85 -> EM85
I replaced the heater chain series resistors and the NTC by a 4.3 µF MP capacitor and both 18 V 0.1 A dial lamps by 3.8 V 0.3 A flashlight bulbs.
After turning it on, the radio worked immediately, and it worked better than before, 'cause most probably the UL41 power pentode had become tired and I've found a very fresh PL82 as it's replacement.
Best regards!
Reactions: 1 user
tv tubes rock!!! Happy New Year to all tube lovers out there...
here are two of my SEP's, single ended pentodes, no global negative feedback used..
output tubes were 12gt5 and 40kg6 aby driven by 6bn11 all in pentode modes, screens are regulated using CCS and Mosfet voltage followers...
  • 323454756_5324730757626444_2521215794327499056_n.mp4
    2.8 MB
  • 322044026_8866118510094814_8377792196398397382_n.mp4
    2.8 MB
Reactions: 1 user
Fully agree that they rock!
Can you tell about the output impedance and frequency response of these amplifiers?
Pentodes, no GNFB imply high output impedance, SE OPTs have lower inductance (than a PP), so I am trying to see how much power one gets at say 20Hz. Or is there some local feedback?
Many thanks!
Erik
Many thanks!
Erik
plate to grid circuit feedback used 200k -150k resistors...i do not have a setup to measure those...
Anybody got triode curves for 6P44S?
I'm using them in a Modular Amp and they sound fine but I've never seen a curve. Judging by how they work though, they are similar to EL500 (even though some say 6P36S is EL500 but 6P36S has bigger balls) :)
Both need about the same bias.
Exactly the same amp but 6P44S (40mA) sounds better than 6P43P (30mA) in this setup IMHO. Probably just the fact they have a lower Rp and more current to give I guess.
Yes, TV tube may rock brilliantly! In the 1960ies and early 1970ies German musical equipment manufacturer Hohner did an amplifier line that mainly featured TV tubes (PL84's, PL519's as finals, PCF200 asamplifiers and phase inverters...). Their Orgaphon 50 squeezed more than 40 w output power from a pair of PL84's (but used ECC808's in the small signal stages).
Best regards!
