Then all the resistors should be accounted for....I used two 49R9/1w Dale's in parallel.
As for the GB on parts, we still do not have sources for all of them and I do NOT have time to research them now. I listed the parts that were MIA from Mouser, if we find a new source that has all, or one additional source that has what Mouser can't supply...
Anyone can find the parts, and get a price for 50 kits. Then we can add the 3% paypal, the shipping, and a few cents per order for envelopes and waa la the kit price. I will then collect the money, order the parts, kit out the parts and mail.
Write down how many of each value is needed and if it's ok to put two in parallell for the last missing one and i'll send them a mail. I'm asking for the amount since i'm not a 100% sure and don't wish to mess things up
I'll be arund the computer for the next 7h (just started my shift)after that not untill tomorrow.
EDIT:
This is what is needed, right?
47,5Kohm 1/2W 105pc
100ohm 1/2W 490pc
1,5Kohm 1/2W 42pC
100ohm 1W 105pc
49,9ohm 1W 210pc (105x2)
kmj said:Write down how many of each value is needed
Parts required for 50 channels. We had a pre-request for 42, and then 4-8 more. I would order 60ish channels for spares/mail losses.
Digi-Key parts
Part # Total
MPSA92RLRAOSCT-ND 150
MPSA42RLRAOSCT-ND 150
MJE15033OS-ND 100
MJE15032OS-ND 150
1N4148FS-ND 100
1SMB5935BT3OSCT-ND 100
Mouser parts
Part # Totals
71-RN65D-F-1.0K 50
71-RN65D-F-22K 150
71-RN65D-F-47.5K 100
71-RN65E-F-4.7K 150
71-RN65D-F-1.5K 200
71-RN65D-F-9.1K 250
71-RN65D-F-100/R 200
71-RN65D-F-3.32K 100
71-RN70C-F-100/R 100
71-RL20S-G-820/R 50
71-CCF02-F-25 100
R105, R126 100
71-RN65D-F-100/R 100
RB1, RB2, RB3 150
71-RN65D-F-100/R 150
RE1, RE2, RE3 150
5982-15-300V680 50
647-UVZ1E102MPD 100
505-FKP10.1/400/5 100
5982-5-300V47 100
5982-5-300V100 100
647-UVZ1H100MDD 100
I had originally figured 42 channels x 25%, but have since been told 25% was to much for spares.
ok, but mouser or digi-key had all components exept these, right?
47,5Kohm 1/2W 105pc
100ohm 1/2W 490pc
1,5Kohm 1/2W 42pC
100ohm 1W 105pc
Wellbourne doesn't stock some of the others so isn't it as well just to order the missing resistors? (Since you posted transistors and such as well i read it as if you wanted everything from welborne, I'm probably wrong but anyway...)
47,5Kohm 1/2W 105pc
100ohm 1/2W 490pc
1,5Kohm 1/2W 42pC
100ohm 1W 105pc
kmj said:ok, but mouser or digi-key had all components exept these, right?
47,5Kohm 1/2W 105pc
100ohm 1/2W 490pc
1,5Kohm 1/2W 42pC
100ohm 1W 105pc
To my knowledge Digi-key does not have the Dale resistors we were looking for. I may very well be wrong.
Resistors and caps were from Mouser.
Semis were from Digi-Key.
If Welbourne has the missing Mouser parts I can order from there.
Have you by chance checked the availability of the parts from Welbourne?
kmj said:Attention Shoppers!
Welbourne has the resistors in stock and they can be ordered online.
Nice!!
I also send an email to http://www.thlaudio.com/indexE.htm this morning and waiting for reply. Maybe we can get a better deal from them...
Welborne charges 257$.
This is without discount and shipping.
Quantity Discounts: Discounts on quantities are available. Our first discount is the standard 10% discount on orders totaling more than $150.00. If you make it past the $150.00 mark with any one product, we will provide quotes for additional discounts if they apply. Products marked "ND" indicate a non-discountable item.
Mark A. Gulbrandsen said:WOWIE ZOWIE Boardman....... They have arrived by UPS RED today! Here are some preliminary photos of them..... Look for better photos later tommrrow.
Mark
Sweet!
Look at the table buckle slightly under the weight of 200 PCB's
Mark
Hi Mark,
Looks good. May I ask which DIY amp that is in the background?
I know this is probably been asked before but I wonder if we could do a GB parts order for everything but the transistors for those of us who already have our supply of those. Would that make things too difficult to sort out? Since the semis are all coming from Digikey we could just reduce that order and keep the others the same.
What do you think?
Thanks, Terry
Yea, and these are .093 FR material and 2 oz copper!!
I'm waiting.....
Eugenio... did you order any... I don't remember your name...... Just kidding .
Terry, Thats a Mini Aleph..... Does about 12 WPC into My Yamaha NS-10's.....
Mark
Mark
Very nice!
I don't remember, did we get the scoring sorted out? Are the boards scored?
Thanks, Terry
- Krell KSA 50 PCB
