Building the TU-8900
V- cap orientation
I too am having a brain fart. Do I have the v-cap
installed correctly? Outer foil facing anode. Is this right?
I’ve confused myself.
@Hifihunter , I noticed your build has TAKMAN TEX resistors. Did you order them separately?
In a moment of weakness early this morning after working long hours yesterday. I ordered a TU8900 kit from Victor. I will be sharing my build here also.
I haven't received the kit yet, I wonder if it is worth upgrading the resistors.
I ordered Takman from Hifi Collective. They have a good supply of all the values needed. They fit better in this amp than in the 8600.
I’m still confused as to which is best direction for vcap install? I was thinking that the anode of the 12bh7 is the lowest impedance path to ground. Maybe there is some difference of opinion on this. Vcap website says that the green side is the outer foil.
The input side of the cap sees the plate and the plate resistor in parallel.
The output side sees the grid resistor (which is much larger).
So the outer foil goes to the plate.
A high impedance circuit node is more sensitive to noise pickup, and the outer foil
(when driven by a lower impedance) helps to shield it.
