TPA3250 somebody is listening?
Hello gentlemen!
I became the proud owner of FX 502S PRO, so I am trying to raise the topic. The best option for replacing operational amplifiers has been discovered. This is OPA 1656 (I think 1612 will do the same). The sound is qualitatively different from all the options offered here. (adapters for DIP required)
Now this kid will be able to surprise many fans of high-quality sound.
Good OpAmp. However, OPA 1656 surpasses it in all basic parameters by two times. But, most importantly, the microchip allows and is optimized for power supply from 5 volts.
And about the musicality of NE 5532, you can talk for a very long time. But, the sound of 5532 from TI is inferior in "musicality" to 5532 chips from ON Semiconductor.
I wonder what parameters OPA1656 is twice as superior to NE5532?
According to objective parameters, the former is ten times better.
For NE5532 supply voltage from 6 V, but this parameter does not affect sound quality, since in FX 502s the op-amp supply voltage is about 20 Volts.
But I agree that the sound is much better with the OPA1656, you can't argue with that. However progress ...
I was wondering if there was a way to get an analog line out from the onboard USB DAC, so I opened it up, but instead found that this capacitor was broken. I was broken on one end only at first and then when I touched it with a plastic probe to check, it complete fell off. I'm guessing it drives the subwoofer out which I don't really use anyway.
In anycase, is there anyway to get an analog out before it hits the power amplifier stage? Sorry if this is a naive question. Thanks!
I have changed a few things in the design. But, beforehand, I carefully studied this topic here. The most important and significant for the sound is the change in the output voltage of the power supply. At least 27-28 Volts should be supplied to the amplifier from the power supply. In general, the stock power supply unit is not capable of providing full-fledged sound quality. And you need a power supply for a voltage of 30 volts and a current of 8 amperes. Also in the amplifier, I replaced the output capacitors ( of dubious quality 1uF x 63V for high-frequency polypropylene Panasonic 1uF x 250V), I also replaced NE5532 with OPA1656.
Also, I replaced the input electrolytes marked in the photo with Elna Silmic II electrolytes.
(10uF x 35 V)
Of course, in these positions it is better to use good polypropylene (2.2uF), but on the board there is no space for them :-(
