MUSES 72320 electronic volume
Disabled Account
Joined 2002
If anyone here had a chance to compare the sound quality of the frankwilker and meldano devices?
The question is in op-amp, if it influences the sound, looks like Meldano follows Mr. Pass philosophy and Frank prefer to follow the Muses spec.
All respect to Mr. Pass but no "Pass philosophy" here whatever that may be. Both circuits are NJR MUSES 72320 datasheet information.
I guess that Pass uses no opamps, just his own circuitry for gain, while the other does. As written, both approaches, with or without opamps are all in the datasheet.
I'm currently finishing a psu with standard 7815/7915 (for analog Muses) with two 7805s (one for digital Muses and the other for the controller / display). I'm very much interested in comparing it with modern low THD LDOs (I have another Meldano kit with I-Select)
I guess that no-one has done it and could give some subjective option if it's worth the effort
In the picture the psu and Muses pcb are placed under Salas I-Select
Disabled Account
Joined 2019
Thank you Meldano,
I have your kit (a stereo one) with the controller but unfornatully was waiting some dac to integrate it at output :)
What is the best regs that not waste the volume controller please for the Muse chip , defintly the NJR 78/79xx or disearve a better (as I also have some other on hands : Ti, LT, etc) ?
Joined 2017
wow.
These regs/psu look cool. But pricey their shipping is indeed.
Found just one other who seem to have similar, though inferior?, developments: audiophonics.fr (with seemingly identical stuff on alibabamazon for 2/3 the price...)
mpaudio.net has no pos/neg, just single or dual rails. They sell quasimodo-boards too ???
So I'm filling a DigiKey-basket (CHF 21 / € 19.50) to see what this gives... soldersoldersolder :)
(Actually, I'm either weird or hooked: Salas told me I could take the 15V directly from the Mez B1, dunno why I should—or must—go nuts on a PSU)
Hello everyone,
A short explanation of the design of my Stand Alone Potis. The used OpAmp (a NJR) by the way, is only used by the Muses chip when it is in gain mode.
This mode is not used in my version. So it has no influence on the sound and could simply be left out.
The coupling capacitors can also be removed if it is ensured that no DC voltage is present at the input or output.
