EL509 (JJ) or PL519?
A couple of other operating points to 4.8K load PL519 El509
any way, you do not have to make up your mind now, but make provisions for a ground dc lifter, when the amp is running listen for spluttering noise on your speakers, if you hear none, then congratulations, you do not need to do anything more....
but if you did hear some noise, connect the dc lifter on the first tube and that should clear the noise..
there is an unwritten rule with tube circuits, that is never leave any element floating however if unused.....filaments included...thus we see in many cases, one side of the filaments connected to ground...
