Marantz CD63 & CD67 mods list
After modding a Marantz CD63 and a CD67OSE I decided to make a list of all the various mod's I found here and elsewhere on the internet.
I'd like to donate my files to this forum, for all to enjoy! :D
Of course I do not pretend this list to be complete. :whazzat:
This is all I've done to the players so far and more good tips are welcome!
Greetings,
Ray.
  • cd63 mods.pdf
Re: Re: Marantz CD63 & CD67 mods list
navin said:
will these work on a CD63 KI?
Hello Navin,
The differences between the CD63 and the -KI are mainly mechanical, and the KI has a toroidal transformer.
The CD63KI uses the same PCB as far as I know, so the tweaks apply to the KI also. It's possible that a few components (like caps) have a bigger value already, but you can replace them with better low-ESR types.
Ray.
I have done similar mods, more in some areas but I have not touched the HF amp caps or the HDAM.
Q: What benefit have you gained from this?
Q: What difference do you hear bypassing the HDAM?
I do recommend you fit a clock. This player loves a good clock.
Also Supply the DAC and Decoder with a dedicated REG so that they are seperate from the rest of the noisey circuit, you will be suprised how well this works.
I have changed all the resistors around the op amp to 0.1% tol type + silver mica caps.
I will have to post my 63KI mods too!
Thank you very much for sharing this fantastic list of modifications. :nod:
I too have a CD63ki and I have used an Audiocom clock with a dedicated external supply, I installed new op-amps (OPA627bp), and have changed or removed dozens of other components (eg. removed muting transistors and dc blocking caps). The sound is very good.
I have yet to play with the regulators, but this is something I'll look at soon. Also, I have not touched the HDAM, yet.
From your PDF:
"the HDAM-circuit looks nice, but when moving up to better opamps and interconnects this circuit starts to
interfere and degrades sound quality. To disable HDAM: remove R651...654 (+/- 12V), R617/618 and
RH23/24. Insert wire jumper at R619/620."
I have good op-amps and interconnects etc., so it is time to try this mod. Without having the service manual in front of me, I cannot picture how your changes bypass the HDAM - does the wire jumper from R619/20 bypass the whole circuit, if so where does it connect, at the phono sockets?
I second Brent's question about how it affects sound quality.
Thanks and regards
rowemeister said:
The four resistors R651 - 654 supply the two HDAM circuits with +/- 12V.
Ok, nice. Better lift those then.
rowemeister said:
R617 and 618 are the audio input resistors, these need removing to stop audio entering the HDAM.
Fantastic, yoink they'll go!
rowemeister said:
RH23 and 24 are the output resistors from the HDAM, removing these prevents audio going backwards into the HDAM.
Splendid, a similar fate awaits said carbon devices.
rowemeister said:
Resistors R619/620 bypass the whole HDAM (like in the CD43/53)
This was the part I understood less well - how can there exist resistors that bypass it when it's not meant to be bypassed in this player? Are these just not connected normally then? Just unused spaces?
I may even pop the hood this evening and have a tinker. I'll probably break it :cool:
Cheers for explaining what the bits do. :yes:
rowemeister said:
SIMON.
rowemeister said:
The bypass resistors are not fitted on the CD63/SE/KI.
They are fitted to the CD43/53 ;)
Hi guys!
Thanks rowemeister, I have nothing to add to the above!
You will find the sound without HDAM more open and transparent.
It's one of the well-known veils that will be removed ;-)
A dedicated clock with proper PSU indeed works very well (another veil) ;-)
Ray.
Well, now you've got my hopes up ;)
Thanks for your quick reply and comment.
Could this effect be likened to comparing an active pre-amp with a passive one? I hope not, as this would mean a loss of bass and dynamics (but the benefits above). You may consider this question as rhetorical, as I fully intend to perform the surgery on my player and report sonic changes, if any.
Ahha, nice pic, and yes I entirely agree - a clock (only with fresh psu tho) transforms the player.
Might I humbly suggest you try OPA627bp on daughter-boards, as it looks like you're using OPA2132/4 or something (can't quite make it out). And 627 pees all over them.
Thanks.
Thanks.
Hm, sharp vision you have... Don't worry, the 2134's are temporary, since this picture is made when the player was still on the workbench...
Ray.
Re: Various opamps
6h5c said:
Here's a list of some opamps and their data. I tried most of them in my CD67. The ones with some form of comment in the Pref. column are favorites. The data helps me to establish a relation between the numbers and the fact that a certain type sounds good.
Ray.
Interesting, thanks for sharing. I see the 627bp is there ;-)
But not LM6172, Thorstoen's favourite when he modded this player. I bought this one to try but since 627bp was so mindblowingly good I didn't bother trying. I actually use LM6172 in my preamp, which gives a detailed heavyweight solid sound.
