This ampl. is not working.Ic 4749 become very hot
Your Inverter IC BAD.Check both inverter IC and Gate driver IC
MANOJ
MANOJ
Dear manoj plz.give me yours whatsapp no.
Hello sir what is difference between 74HC00 and CD4049 ??
74HC00 is a NAND gate,it is a TTL so it can handle max. 6v DC.
CD4049 is a NOT gate,it is a CMOS it can handle max.18v DC
74HC00 you can used as a NOT gate if you shorted both input
MANOJ
Anyone want schema pls PM me (email ID)
MANOJ
Good Morning.
Could you send me the layout of your aud200u amplifier?
Thank you.
luizcpimenta@gmail.com
Good Morning.
Thank you.
i also want sir
alvi.masood251@gmail.com
regards
Thank you.
SMD version or normal
MANOJ
MANOJ
Good Morning.
Normal.
If possible send me other schemes of yours too.
Thank you.
Good Morning.
Normal.
Thank you.
Pls check your mail, you can use layout 5 & 6
MANOJ
MANOJ
Good afternoon.
I received nothing.
Did you get the files I sent you?
- Class D
- My class D amp
