Simple High Performance DC Coupled Class A HPA with sub PPM THD
Founder of XSA-Labs
Joined 2012
Desktop amps generally have RCA inputs and 1/4in TRS outputs, but we have JST connectors so you can wire your favorite connectors with leads. To have it on the board will force people to drill very exact holes on their panels and will be too restrictive.
One thing we are considering is to make the PCB a perfect fit for the $36 Aliexpress case with all holes precut (except for Xfeed bypass). That would force everyone to get that case but it would be a nice integrated "turn-key" solution.
Founder of XSA-Labs
Joined 2012
We have so many options right now built into board that we may need simplify by removing some features. For example, switchable cross feed is sort of hard to implement with switchable AC coupling. This amp’s raison d’etre is really the fully-DC-coupled topology, so I think we may leave AC coupling as some solder pads for installing a small box film cap and leaving out a wire jumper for DC-coupling. Even adding passive cross-feed upstream of pot requires forcing pot to a specific value (10k) in order to fix the input impedance of amp to ensure stable slope and frequencies of the cross feed filter.
Founder of XSA-Labs
Joined 2012
More progress on integrated amp from JPS64. Note how JPS64 maanged to stuff a cap Mx onto the bottom side of the already full PSU board via use of SOTR223 MOSFETs.
Some amazing work there JP, simply beautiful and professional layouts never before seen on DIYA. We really are lucky to have you spinning boards for us.
attachment.php
attachment.php
Nifty. I wasn't referring to the adjustability so much as this amp's low distortion with H2 dominance. Bob sez:
"No distortion sounds better than a little bit of bad distortion, but moderate, well-distributed distortion sounds better, too!"
This amp seems to nail it on both counts. Although I guess with ultra low THD, we will get very little H2 to magically "mask" the higher harmonics, so the overall sound becomes heavily dependent on the sound sig of the source.
Founder of XSA-Labs
Joined 2012
This can tweaked to user's desires by setting bias current and/or putting asymmetric Source/Drain power resistors, and also by choice of feedback resistor materials, and bias current setting. 400mA is smoking hot (14w per channel) and THD is <1ppm, whereas at 100mA bias current it will be closer to 0.005%THD (all H2). 100mA is plenty for most headphones and only 3W dissipation per channel.
Well, I've got these darn power-hungry Fostex planars. So lowering bias will probably not be a good option for me...as it would increase not only the H2 of the amp's output signal, but also probably significantly increase distortion of these 50 Ohm, 92dB sensitivity drivers.
My LingDAC has a SE Class A buffer, so hopefully I'll have a good distortion profile from the get-go, and this amp will simply "do no harm" :)
Founder of XSA-Labs
Joined 2012
Working with JPS64 on prototype PSU with hone etched board to test our concept.
System has CMC choke, DC-DC isolated step up with dual +/-24v outputs, followed by Texas Instr LDO VR’s, then a capacitance multiplier for slow ramp up starting, finally a CRCRC to clean it all up.
Here is the etched board ready to be drilled.
This could be a handy dual rail PSU for any application where you want ultra low noise supply wothbup to 310mA and up to +/-20v with simple 8v to 18v input.
Founder of XSA-Labs
Joined 2012
Given the success of the critical new DC-DC dual rail PSU, any new interest in this GB given no need for working with mains voltages needed for this amp?
Badboygolf16v - 1 pair
Dabore84 - 1 pair
funch - 1 pair
kartk - 1 pair
Yourownbuzz - 1 pair
BabyDontHertzMe - 1 pair
Stellarelephant - 1 pair
passive420 - 1 pair
Pinnocchio - 1 pair
vvs7 - 1 pair
sarathssca - 1 pair
Gwrskien - 1 pair
Count me in too! Looking forward to A/B'ing the Whammy, AKSA Lender, and this one!
Dabore84 - 1 pair
funch - 1 pair
kartk - 1 pair
passive420 - 1 pair
Pinnocchio - 1 pair
vvs7 - 1 pair
sarathssca - 1 pair
Gwrskien - 1 pair
Ernesternest - 1 pair
jwjarch - 1 pair
